rgnoble
rgnoble
Last Active: 9 Years Ago
Visits: 25
Can anyone tell me how to attach a prop to a character using the layer editor. The help file is horrible.
AverageJoe
AverageJoe
Posts: 2.4K,
Visits: 10.1K
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
If you want a prop to be able to be layered within a Characters layers then the prop needs to be added to the Character in the Composer mode. Then using the Layer Editor you can move it behind and in front of the various parts of the character. With a prop added to a Character in Composer mode it will always be "Attached" to some body part. Default is typically a hand. Use the Attached button in Composer mode to move the attachment to any body part. Jeff
AverageJoe
AverageJoe
Posts: 2.4K,
Visits: 10.1K
I don;t remember if this is an issue in CTA2, but I remember from CTA1, the prop itself had to have an absolute key of 0, 0, 0 in order to be positioned correctly when attachng to a character. Even the props directly from RL had to have this done, which was kind of a PITA... Being the prop to the stage, open the absolute key dialog and set it to 0, 0, 0 for all 3 axis, then re-save the prop (which would now be a custom prop, thus a duplicate). Then you could drag into the composer and attach without any untoward side effects.
So if you attach a prop in the composer without doing this, it may appear correctly but if you exit the composer back to the stage, and you're using an orthographic camera view, the prop will not be aligned properly on your character.
Just an FYI in case things go or appear wonky.
rgnoble
rgnoble
Visits: 25
Many thanks for the help. When I attach a prop to the character in the character composer, then go back to the stage the sizing of the object changes. Thanks again for the help, I will try the 0, 0, 0 and see if that helps.
