iclone6 ver. 2.2
Gentlemen I have a problem:
In my project I have a relatively old movie file used to map a flat prop, plus one avatar.
VIDEO CODE: mpeg
Frame rate : 25/sec
Size: DVD format: 720x576 - european Std
Movie length: abt 7 minutes
In the RENDER windows I select the same frame size (720x 576)
In the FORMAT choice I tried to use, once at time, all the availabe 3 formats: AVI, MP4, WMV,
obtaining the same result.
Apparently, in the RENDER windows I CAN NOT change the FRAME RATE , that is fixed at 30 FR/sec.
So it means that- in any case - the RENDERED movie will play at 30 FR/sec. This fact would not be
a problem.
BUT...looking at the result you will notice a very bad fluidity of the original movie while the
Avatar is perfectly working.
It seems that the transcode process from 25 to 30 FR/sec is causing the problem or what else?
Thank you for any help.
Gianni
9 Years Ago by
giannigodi
