AlaaSerry (8/30/2015)
@Liebe: CT7and its Unity plugin works fine in the Unity Editor. However, when I tried tobuild an executable targeting the Windows App store, I get tons of builderror!!
Let me knowif you were successful in building an executable targeting the Windows App storeplatform from a simple Unity project using CT7 and its Unity plugin. If that isthe case, then perhaps you may want to share your experience and a sampleproject.
Thank youkindly.
Ah, I see , you mean for Win Ap store build . Unfortunately I have not Window 8 or 10 . I can not compile with Win 7 .
Are you sure it comes from CT7 Plugin ? Maybe your WIN SDK are not correctly set. I had this with Android SDK with wrong path. After correct setting it was working .
Important is to read and understand what the error message means.
Also you can put this error message in google search and maybe you can find a answer . often have User the same Problems and asked it already, and got a Solution.
A note. your postings are very hard to read.
Black fonts to black Background is not readable.
liebe Grüße vidi
9 Years Ago by
vidi
