G5 Soft Cloth RE: editing Chuck Casual soft cloth UNDERSHIRT
Posted By CaseClosed 9 Years Ago
CaseClosed
CaseClosed
Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)Distinguished Member (3.3K reputation)
Posts: 344, Visits: 781
I am trying to customize the G5 Chuck Casual CloneCloth. Chuck Casual is a button shirt over an undershirt (T-shirt). I was able to texture the diffuse and opacity for the button shirt, but I can not see how to edit the diffuse and opacity of the Undershirt.
Can someone point me to where the Modify- Material settings are for the Undershirt? Thank you!
9 Years Ago by bbvb17
Last Active: 11 hours ago
Posts: 15.7K, Visits: 30.5K
It looks like it is a single mesh with a single texture with the collar in a separate area (called Undershirt for some reason). Anything above the collar on the main texture would be the T-shirt. I've colored orange (not very well) the T-shirt part on the CloneCloth template.
https://forum.reallusion.com/uploads/images/093580aa-8834-4008-8096-8065.png
Opacity adjustments would be in the corresponding area of the Opacity map.
9 Years Ago by animagic
CaseClosed
CaseClosed
It's part of the outer shirt.
I discovered that right away in my diffuse map tests. I made that area invisible in the opacity map so the outer shirt lines up with the collar.
The area on the main texture that says 'Undershirt' does not actually affect the Undershirt: it's the collar, and that's where the frustration begins.
ChuckCasual upper layout_v001.jpg (261 views, 499.00 KB)
9 Years Ago by CaseClosed
Posts: 22.7K, Visits: 35.7K
bbvb17 (7/21/2015)
Actually, that area is till part of the outer shirt. I discovered that right away in my diffuse map tests. I made that area invisible in the opacity map so the outer shirt lines up with the collar.
Hi..
If you want to remove the collar, say for a round neck t-shirt, just make the Undershirt area black on the Opacity map.
CaseClosed
CaseClosed
I figured out what I was doing wrong. In my lighting tests with indigo renderer, I had turned the ambient color to white on many objects including the upper skin. Haha, oops.
I turned the ambient color back down, and the 'undershirt' disappeared. Voila.
You were both correct of course.
Sorry for the trouble, and thanks for taking the time to reply.
