tonk (7/20/2015)
Hello Reallusion,
I have another very important wish for the next version of CrazyTalk Animator.
In Europe the TV-standard is 25 frames per second. When starting a new project I have to accept the 30 fps
preset which cannot be changed.
When rendering the project in AVI format with 25 fps, the video is stuttering and does not keep the original length.
(Besides, why did you give the user this option when the video will be stuttering?)
If you want to sell a video to a TV station you have to convert it with very expensive software or hardware.
Some TV stations do not accept any converted videos made in 30 fps.
Is there some hope that the developers of CTA might hear my wish?Thank you for the feedback.
The issues you report should not be happening. If you export @ 30fps or 25fps the length of the video should not be different. The frame rate just indicates how many frames will appear in one second. So a 60 second video @ 30 fps should still be 60 seconds @ 25fps. Only the number of frames will be reduced.
Also visible stuttering should not be occurring. Perhaps you can send us the video that is stuttering so we can see what you mean. Please use the Support Form below to submit your video for testing. We will then be able to see if the results you are getting are correct or not. It may be that there is an encoding issue, possibly with a faulty codec or setting.
http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspxThanks.
