Hi, look to the left in your scene panel, and turn off the "Dummies" by clicking the eyeball icons in the right-side column.
In the scene panel, you should be able to spin some of those open to view items - hopefully the butterflies - "attached" to the dummy boxes. You'll want to make sure they are visible in your scene by clicking the eyeball icon "open."
See, in iClone you can group items by attaching them - by using the "Attach" panel in the modify panel, on the right. Once an item is attached to another it will appear in the Scene Panel underneath the item to which it is attached.
Once you have an item attached or "Parented" you can MERGE the objects into one item or prop. You do this back in the Attach panel which is part of the Modify Panel. The option to Merge is only available when you have a group of Attached objects selected.
You can also link things so that one object will follow or duplicate the motion of another object. This is handy when you want to pass an object from one prop or character to another. Warlord has a very good video about this that should come as part of the iClone training DVD, or you'll probably find it on youtube.
Good luck!
9 Years Ago by
JC Weatherby
