Good News,... I did some test at home and it all works for me
So here is what I did... First thing to know is that you need to use the
Base Characters iProp and not the Pre-Build Crowd Groups because the root Prop for Pre-Build Crowd Groups is a Dummy and 3dXchange will not see the motions and therefore will grey out the export motion option (although the motions are there). I assume you tried using the pre-build Crowds and that is why it does not work.
So try this:
1) Start 3DXchange
2) Open either Gwynn or Chuck Base characters, they are called '
'Small Crowds Runs & Panic_Base1F'' and
''Small Crowds Runs & Panic_Base1M''. These character hold an example of all motions in the pack.
3) You should see the motions in 3DXchange (see Pic..) and be able to export them.
Hope this helps...
Come and visit my store by clicking on the banner below.
