Using your favorite drawing package create a Circle (or some shape) and fill with your desired color.
Export to a swf file.
Open CTA.
Drag and drop your swf file onto the stage or use the "Create Media" button to create a prop using your swf file.
Your filled shape should now be on the stage.
Select the filled shape.
Click on the "Prop Composer" button. This takes your filled shape prop to the Prop Composer area.
Now click on your object to select it then click on the "Vector Grouping Tool" button on the left.
On the right side of the window you will see a vertical column titled "Group Name Selection".
Click on the name of the group you wish to color in your actor.
Then again on the far right click on the index that causes your filled color to flash.
There are typically one or two items in the list, index 0 and possibly index 1 for a basic shape. One is the border (if any) and the other the filled area.
Once your color is flashing and you have selected a name in the "Group Name Selection" (i.e. Upper 03), click the "Apply" button in the lower right.
Now click on the "Back to Stage" button (upper left) and your object is back on the stage.
Place your actor on the stage. Select your filled colored shape, then click on the "Apply Selected Render Style" button (top middle) and your cursor turns into a bucket.
Place your cursor over your actor and click on the actor.
Your filled color will now be applied to that character only to the Group Name you previously selected and applied to the filled color shape.
(i.e. If you applied the Upper 03 to your filled color shape then any part of the actor that has the group name of Upper 03 will change to the color of your filled object.)
Jeff
