weight map help
Posted By hcameron90 9 Years Ago
hcameron90
hcameron90
Posts: 295, Visits: 2.0K
I have a problem on a weight map.
I am using G5 eddie basketball avatar. I am adding a weight map to the shorts.  (http://www.reallusion.com/ContentStore/ccdproduct.aspx?contentid=AIC551CIENU012020140910003)
 1st I added the collision shape to the avatar and edit the shorts weight map in PS.
 2nd I added a running motion to the avatar in Frame Mode and it works fine.
However when I play it Realtime Mode the cloth still goes through the avatars leg. Now I edit the map a few times to gray some of the white areas but still the cloth breaks through.
Is there a way to fine tune this specific weight map
prabhatM
prabhatM
Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)
Posts: 1.8K, Visits: 8.1K
For the final result, you should depend on the FRAME mode.
Lord Ashes
Lord Ashes
Distinguished Member (20.8K reputation)Distinguished Member (20.8K reputation)Distinguished Member (20.8K reputation)Distinguished Member (20.8K reputation)Distinguished Member (20.8K reputation)Distinguished Member (20.8K reputation)Distinguished Member (20.8K reputation)Distinguished Member (20.8K reputation)Distinguished Member (20.8K reputation)
Posts: 1.3K, Visits: 1.6K
Slower movements also tend to help because the cloth has time to adjust.
If you need fast action, consider recording the action much slower rate and then speeding it up in post production.
Posts: 8.2K, Visits: 26.5K
Lord Ashes (7/6/2015)
If you do that (slower motion), do you also need to reduce "gravity" by a corresponding amount?
I'm thinking you'll need to, or the cloth will fall too fast when you speed up your video in post.
JC Weatherby
JC Weatherby
Distinguished Member (6.3K reputation)Distinguished Member (6.3K reputation)Distinguished Member (6.3K reputation)Distinguished Member (6.3K reputation)Distinguished Member (6.3K reputation)Distinguished Member (6.3K reputation)Distinguished Member (6.3K reputation)Distinguished Member (6.3K reputation)Distinguished Member (6.3K reputation)
Posts: 477, Visits: 802
You actually have to go higher contrast on the weight map.  Blacker blacks and darker grays.  Then - yes - do a lot of experimentation with the settings.  But I found making sure you have a high-contrast weight map - even with a gradient - is essential.
45thdiv
45thdiv
Posts: 209, Visits: 694
I struggle with this all the time.  I have also used the collision editor to help expand the ratio.  I don't get enough time in front of the computer these days to practice, but I have also heard that the contrast ratio is important.
Matthew
Matthew
PC stats:
Intel Core i7-5930K Processor (6-cores, 15MB Cache, Overclocked to 3.9 GHz with Turbo Boost)
Windows 10
Graphics card NVIDIA GeForce GTX 1080 graphics, 8GB
Memory - 16GB Quad Channel  DDR4 at 2133MHz
DirectX - 12
256GB SSD 6Gb/s main HD + 4TB 6kRPM SATA 6Gb/s Storage
Cricky
Cricky
Skype ID= learn.iclone
Posts: 2.8K, Visits: 13.8K
If the cloth you are trying to weight map is a separate piece, you CAN turn off the soft cloth once recorded in by frame mode.  That way you can see it before rendering at the Full Speed, without recalculating the soft cloth parameters each time you press play.
https://forum.reallusion.com/uploads/images/622fb3f4-fe7a-454d-b703-328b.jpg.
SKYPE ID: rc.650
