Last Active: 16 minutes ago
Hi Everyone, iClone 6.03 has now been released. This version contains a large number of fixes and enhancements. Can you please post all issues, bugs, glitches, etc. that you find with the iClone 6.03 release here. Of course feel free to post general feedback in your own threads but it will be great if we can keep outstanding issues and bugs here in this official thread. It will make it easier for the development team to track any outstanding problems and get them fixed quickly. Please do try to provide your full system specs and a description of the problem when posting issues as this will help greatly. If you can provide step by step information so we can repeat the problem even better. Thanks. |
Agonos
Agonos
Posts: 1.1K,
Visits: 3.1K
Hell all and thank you Peter Question : Is it possible that the problem with the options "glare" would come from the use of a bad codec ? In any case, the problem disappears using directx 9.
9 Years Ago by
Agonos
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
Thank you Peter, The "Detail" Heightmap terrain bug still there. No opacity control , no tiling control.... I think terrain is a major feature for film making. Best regards
9 Years Ago by
mtakerkart
menro28
menro28
Visits: 637
Hello Reallusión iCloners ;-) Google traductor.
English:
Thank you very much Peter. I'm disappointed. I still go very slow on old projects and new :-(
iClone 3 :-) iClone 4 :-) :-) iClone 5: -D: -D Or :-) iClone 6 :-( :-( :-( 6.01 6.02 6.03 :-( :-( :-( ...
"Indigo Rendered" on stage with props waiting stays. It is faster Sketchup -> Indigo to iClone -> Indigo.
It goes faster iClone 5 Pro, which iClone PRO 6, and without affecting the system.
I miss the Pixel Shading tab (Wireframe, Smooth Shading ...) I was in iClone 5, because when I try to do something in the iClone 6 and see that it starts to get slow, slow much in the program, to put in lower quality to work.
I keep waiting and using other tools iClone 5 and 6 will practice with iClone waiting for a version which creates more stable to have fun with it.
Thank you very much and observe any problems other than stability, and for what I put.
· Different types of Glare, not working.
Spanish: Muchas gracias Pedro. Estoy desilusionado. Me sigue yendo muy lento en proyectos antiguos y nuevos :-(
iClone 3 :-) iClone 4 :-) :-) iCLone 5 :-O :-) :-D :-D iCLone 6 :-( 6.01 :-( :-( 6.02 :-(:-(:-( 6.03...
"Indigo Rendered" en escenarios con props se queda a la espera. Es más rápido de Sketchup-->Indigo que de iClone-->Indigo.
Va más rápido iClone 5 PRO, que iClone 6 PRO, y sin que afecte al sistema.
Echo de menos la pestaña del Pixel Shading (Wireframe, Smooth Shading...) que estaba en iClone 5, porque cuando intento hacer algo en el iClone 6 y veo que se empieza a poner lento, tardo mucho en el programa, en poner en calidad más baja para poder trabajar.
Seguiré esperando y utilizando el iClone 5 y demás herramientas y practicaré con iClone 6 a la espera de una versión que crea más estable para divertirme con ella.
Muchas gracias y cualquier problema que observe aparte de la estabilidad, pues lo ya lo pondré.
· Los diferentes tipos de Glare, no funciona.
· I7 960 3.2GHz 24GB RAM · · Nvidia Geforce GTX 650Ti 2GB VRAM · Windows 7 Ultimate Servipack one·
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
Tabbing from one motion to another I see has not been fixed. The Tab should start at the beginning, hit tab to advance, and then it should go to the end of the same applied motion(s), so more can be added easily. If you want an example of how it did work, check previous versions of iClone. It comes in quite handy to do this simple tab option.Inching forward to the end of a motion is not the way to move from one to another.
SKYPE ID: rc.650
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
Supergerry
Supergerry
Visits: 106
After 5 min test: Not Fixed - Spring No Longer Works after resizing with Avatar AVATAR PROPORTION - After loading * rPectoral and lPectoral .spx change to CHEST, so no separate change possible - Tons of gigabytes on HD, very little RAM usage, so the program is very slow - Crashes on startup if unsaved data of projects were found - Play / Stop bar not removable / displaceable to enlarge the main screen
New error: AVATAR Proportion: click, window opens, by default BODY has been selected in the list -> but it is the head in the picture in color -> Changing a slider then changes the head and not the body. Redial of Body in the list does not change, you must first click on the body in the picture, only then it works.
I am absolutely frustrated by this "update" and will not be used further for the time being IC6
------------------------------------------------ iClone 7 Pro (DX11 only), Mocap device plugin, Curve Editor, 3DXchange 7 Homebuilt PC: Windows 7 Pro SP1-64bit, 1kW BeQuiet, MSI Z97 Gaming 5, i7-4790K @ 4,00 GHz Hashwell, 32GB 1600Mhz Cruical, Gigabyte Windforce OC GTX970 4GB, 4-Monitor-Config: 28" on GTX970 only with Iclone`s main window, 2x 21" on the Intel HD4600 ports with all other tabs (timeline, scene- & content manager...), HUION GT190 TouchPen Monitor
Supergerry
Supergerry
Visits: 106
Why the German IC6 has not yet been patched ??? This reminds me of earliest Poser times when un-English version were always being updated only after days or weeks. ...
Supergerry
Supergerry
Visits: 106
BUG: Crash when using Mocap device plugin:
Problemereignisname: APPCRASH Anwendungsname: iClone.exe Anwendungsversion: 6.0.1614.1 ----->>>> ?????????????????????? Anwendungszeitstempel: 5535e300 Fehlermodulname: RLHumanCore.dll Fehlermodulversion: 0.0.0.0 Fehlermodulzeitstempel: 5535de77 Ausnahmecode: c0000005 Ausnahmeoffset: 000000000000c890 Betriebsystemversion: 6.1.7601.2.1.0.256.48
