It would be very helpful when using the Vector Grouping Tool to be able to see which groups (i.e. Hair01, Skin01, etc.) have an object assigned to it. Maybe have those group names in a
bold font to indicate something is assigned to that group.
Too many times have I tried to use a group that I thought was not used but then find out it was. The only way to currently see if a group is used is to scan each body part in the Vector Grouping Tool to see if the group I want to use has been assigned, which is tedious.
Also, there is no way to remove a Part from a group. There should be a "unassigned" button to remove a part from a group.
The "Undo" also does not work in the Vector Grouping Tool. I find that if I assign a part to the wrong group it changes the color and there doesn't seem to be a way to undo it.
Jeff
