How To Install The Indigo RT Suite
Posted By Peter (RL) 10 Years Ago
guy launay
guy launay
New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)New Member (16 reputation)
Last Active: 3 days ago
Posts: 1, Visits: 137
Hello,
For install Indigo with iClone 6.1, the only way i found.
1 ) install iClone 6.0
2) install RT Driver v100
3) upgrade iClone from 6.0 to 6.1 (this upgrade the RT driver to v101)
and do nothing else. (impossible to install RT driver v103)
For use the GPU in Indigo for iclone :
edit all .igs file and replace the line <gpu>false</gpu> with <gpu>true</gpu>
Goog luck to all.
cducharme
cducharme
Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)
Posts: 7, Visits: 461
Hi
I installed iClone 6, Indigo Render Plugin and Indigo RT for iClone in this order (as suggested by Peter).
Indigo RT seems to work correctly and is licenced.
The problem is that i have no plugin menu so i cannot command Indigo from inside iClone.
How can i make the plugin menu and Indigo window display?
Howto save iClone project or movie to be process by Indigo RT?
Thanks,
Claude
Lawsuit Pending Records
Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)
Posts: 376, Visits: 2.1K
cducharme (6/13/2015)
Hi
Thanks,
Claude
Hi Claude. I had a few goes at this. You should see plugin tab on the very top toolbar between the tab headings "Windows" and "Help" Only thing I found was  iClone had to be closed when Installing the Indigo plugin or that menu heading would not appear or install correctly
https://forum.reallusion.com/uploads/images/992e4d8f-3217-4368-a94f-f808.jpg
iC5 Pipeline, iC6 Pipeline, CTA2 Pipeline, CTA Pro, Crazy Talk, Facefilter, POP.
LAWSUIT PENDING RECORDS Label-Logos-Web Design-Artist Roster-Licensing - Flip type interactive magazine production
cducharme
cducharme
Thanks for Your advice.
I did uninstall Indigo and redo the install with iClone closed. It worked.
Best regards
Claude
pi-qui
pi-qui
Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)Veteran Member (643 reputation)
Posts: 12, Visits: 44
Hi Peter, my Indigo render plugin has disappeared from the menu bar in iClone the latest version? Indigo RT is still there, but the link to Indigo has disappeared???? It has disappeared from render, what has happened? I reinstalled the 6.2 patch latest patch again, reinstalled Indigo patch 1.0.1 after uninstalling Indigo first. But it doesnt come back. went to the plugin folder, its there but it doesnt show up anymore ....how can I solve this?
pi-qui
pi-qui
I tried everything described here, but the Indigo plugin is no longer showing up in IClone Pro latest version. How can I solve this? Is it a problem with Windows 10?
Posts: 22.7K, Visits: 35.7K
pi-qui (10/7/2015)
If you have ensured you are installing the Indigo Plugin with iClone 6 closed, then please contact our Technical Support department using the link below. To save time please include your dxdiag.txt so we can have a little check of your system settings.
http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
Thank you.
Alien Maniac
Alien Maniac
Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)
Posts: 693, Visits: 2.1K
I have IC 7 installed now and need to install the Indigo RT and IC 7 plugin.
I found the Indigo Iclone plugin in my RL purchases and downloaded it and installed it...there is no Indigo RT  to install....
There are 2 files  PI FOR IC7 AND A REGULAR PI. ONLY So where do we get the Indigo RT program?
I also forgot the exact method of installing both.
Thanks for any help...
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram,  2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor  External data drives total 7 TB. and an AUDIO Studio Recording system.
TonyDPrime
TonyDPrime
Distinguished Member (12.6K reputation)Distinguished Member (12.6K reputation)Distinguished Member (12.6K reputation)Distinguished Member (12.6K reputation)Distinguished Member (12.6K reputation)Distinguished Member (12.6K reputation)Distinguished Member (12.6K reputation)Distinguished Member (12.6K reputation)Distinguished Member (12.6K reputation)
Last Active: 6 days ago
Posts: 3.4K, Visits: 12.4K
Space Rider (12/6/2017)
@ Space Rider - did you get this sorted out,
Here is some info:
After installing the plugin in iClone-
First, go to
https://www.indigorenderer.com/download-indigo-rt
And download the Trial, install just the RT program (it will give you the option to also install plugins, but do not install any of the plugins)
Then, look in
C:\Users\Public\Documents\Indigo Renderer\
Make sure there is a text document called
activation_key.txt
If not, create a .txt there and name it that.
It needs to have just your Indigo serial from RL.  If it doesn't, paste it there...(ie - paste it so the text document's first characters are the serial #)
Then, go in iClone and Under plugins, select Indigo, and one of the options is Indigo Program, Path....
Use this to locate the IndigoRT .exe you downloaded
it should then, upon launching from within iClone, be recognized as valid serial for iClone.
Then, enjoy the most awesome renderings you have ever seen.
And, last, but not least, lament the fact that it is almost impossible to go through the process of exporting an animation for render.
