RealtoReel (8/3/2014)
My copy of CTA 1 Pro suddenly WON'T FUNCTION!
I get an error message that reads:
"Assertion failed
Program...
File.\src\RLM.cpp
Line 168
Expression:ret
JIT must be enabled"
(And my installed copy of IClone 4 no longer functions, either!)_Sorry to hear of your problems.
Sounds like there has been a computer issue if both programs are affected. Please try uninstalling and perform a clean install of the latest versions of both titles. You can get the latest full versions from your Member Account after login.
If this does not resolve the problem, please contact Technical Support using the link below. Do ensure you provide your dxdiag.txt file and a screenshot of the error message. They will then be able to help you get up and running again.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
