Range limits on avatar joint rotation
Posted By justaviking 10 Years Ago
Posted 10 Years Ago
Posts: 8.2K, Visits: 26.5K
Greetings,
Real elbows do not bend 360 degrees.
  • I would like to have some "reality-based" limits put on the rotation of an avatar's joints.
  • The limits should be "generous" to allow a large range of motion
  • You should be able to turn off the constraints (useful if you want to simulate an automobile accident).
Since the physics engine includes range constraints, it seems like a reasonable request to me.
Human IK is great.  But sometimes when moving a hand, for example, the arm and shoulder get all twisted and mangled in ways that are not physically possible (without sending Chuck or Gwynn to the hospital).
Cricky
Cricky
Posted 10 Years Ago
Skype ID= learn.iclone
Posts: 2.8K, Visits: 13.8K
justaviking (5/27/2014)
Greetings,
You have Full Body and Body Part options, which a lot of people overlook.
You should choose the Body Part only option, if moving the hand is twisting the other linked body parts. It makes a difference also on what angle you are viewing the character in when making adjustments.
SKYPE ID: rc.650
Posted 10 Years Ago
@Cricky,
1) It's not a huge problem, but it's been on my mind from time-to-time, so I figured I might as well put in on the list.
2) I mostly use the "Edit Motion Layer" panel.  I've used the "Body Part" setting, but yeah, I think I tend to forget about that setting.
I am much more likely to have a problem with "broken bodies" when moving the actor via an attached prop.  If you do the "sword fighting" action where you attach dummy props to the sword handle, and have your avatar "reach" for the dummies, you can move the sword and the avatar follows.  The avatar also has a tendency to end up with elbows bend backward and dislocated shoulders.
Also, depending on where you are moving... let’s say you a reach from a shoulder to a pants pocket, the arm may rotate strangely.  My solution is to manually find a mid-point to the motion and rotate the arm into a reasonable position, and then move the hand to the pocket.
Thanks for the tip.  I'll have to remember to try that more often.
Posted 10 Years Ago
Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)
Posts: 22.7K, Visits: 35.7K
Thanks for the feedback. This will be reviewed by the iClone team. Smile
Sifr
Sifr
Posted 10 Years Ago
Last Active: 4 days ago
Posts: 644, Visits: 3.6K
It's about time, I've been screaming joint rotation constraints for years now. & don't forget to add a degree counter to the gizmo as well as a shaded pie graph.Wink
Reallusion iClone & CC Pipeline --- Plugins: Iray HeadShot SkinGen.  CrazyTalk Animator Pipeline, CrazyTalk, Maya LT, Daz, Substance Painter Indie, Substance Designer Indie, B2M Pro+ Substance Live, Sculptris, Wrap, Unity, UE4, Perception Neuron ReadySmileBigGrinTongueWinkCoolHeheSmoooothCrazySatisfiedWowPinchExclamationAlienDiscussKissArrowSadAngrySickExclamationBlushWhistlingw00tw00tw00t
SurfaceBook 2 Windows 11 Pro 64-bit Intel(R) Core(TM) i7-8650U CPU @ 1.90GHz -2.11 GHz 512GB Solid State Hard Drive 8GB RAM Nvidia GeForce 1050GTX
Dell  Alienware m18X R2 18.5" Custom Convertible Tablet Windows 8.1 Pro 64-bit Intel Core I7-3840QM 2.80GHz Quad Core 8 Thread 3.2GHz Turbo 512GB Solid State Hard Drive+1TB X2 RAID Disk Drive 32GB RAM Nvidia Geforce GTX 680m 2GB X2 SLI Custom Multi-touch. Dagi capacitive touch stylus
Microsoft Surface Pro 2 10.1" Tablet Windows 10 64-bit Intel Core I5-4200U 1.60GHz 2.3GHz Turbo 128GB Solid State Hard Drive 4GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer screen Surface Pen+Axiotron Studio Pen
Asus Vivo Tab 8" Tablet Windows 10 32-bit Intel Atom Z-3740 1.33GHz Quad Core 32GB Solid State Hard Drive 2GB RAM HD 4000 Graphics Multi-touch Wacom Digitizer Wacom stylus.
davood.kharmanzar
davood.kharmanzar
Posts: 137, Visits: 3.1K
does a chance to see "joint rotation limitations" of character feature on iclone 7 ??
its very useful for recording motion capture movements on realtime ... to getting cleaner results ...
or possibility to implement these: http://wiki.secondlife.com/wiki/Suggested_BVH_Joint_Rotation_Limits
6 Years Ago by davood.kharmanzar
