Timeline and Output do not match
Posted By geraldrice 10 Years Ago
geraldrice
geraldrice
Posted 10 Years Ago
Veteran Member (596 reputation)Veteran Member (596 reputation)Veteran Member (596 reputation)Veteran Member (596 reputation)Veteran Member (596 reputation)Veteran Member (596 reputation)Veteran Member (596 reputation)Veteran Member (596 reputation)Veteran Member (596 reputation)
Posts: 17, Visits: 66
Why is it that my timeline is set to 1500 at 30 fps plays back fine in iclone but only renders half the frames. If I render it at 60fps i get the full 1500 but it is slower. This makes not sense.
It seems like what your project is setup to is what you should get.
prabhatM
prabhatM
Posted 10 Years Ago
Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)Distinguished Member (6.4K reputation)
Posts: 1.8K, Visits: 8.1K
geraldrice (5/7/2014)
I had similar issues when I tested Iclone.
Posted 10 Years Ago
Last Active: 40 minutes ago
Posts: 15.7K, Visits: 30.5K
There is a distinction between the internal fps setting iClone uses for timing, which is always 60 fps (i.e., 60 frames equals 1 second), and the frame setting for rendering, which may vary. So if you render at 30 fps, you will get 750 frames.
That's how it always has worked in iClone. I have no problem with it.
