How to trim my project in crazytalk animator pro??
Posted By westby_andrea 10 Years Ago
westby_andrea
westby_andrea
Posted 10 Years Ago
Veteran Member (785 reputation)Veteran Member (785 reputation)Veteran Member (785 reputation)Veteran Member (785 reputation)Veteran Member (785 reputation)Veteran Member (785 reputation)Veteran Member (785 reputation)Veteran Member (785 reputation)Veteran Member (785 reputation)
Last Active: 10 Years Ago
Posts: 8, Visits: 21
Everytime I delete a frame, or delete the data, all my work (after the part I want deleted) goes to the center of the project screen, it just messes everything up.
All I want to do is "TRIM".... Just completely delete the first 25seconds of my movie. I am new to this program, deleting frame and data keep making my whole project messed up after it "deletes"
Please help!
jlittle
jlittle
Posted 10 Years Ago
Posts: 1.9K, Visits: 17.1K
The first frame holds the initial position of an object (i.e. prop or character).
If you delete the first frame then the objects will move to the next Transform position they were moved to or will revert back to the initial (0,0) position if none.
The thing to do before you delete any frames is first ungroup any of the pre-defined motions for each character.
Then for EACH object on the stage, in the frame just after the last one to be deleted:
1) Create a key on the Transform track, and
2) Create an Absolute key using the Motion Key Editor
Then you should be able to delete the frames (using Project Collect Clip) without the characters and props moving about.
Jeff
