narf2n
narf2n
Posted 11 Years Ago
Last Active: 9 Years Ago
Visits: 333
I am not sure I follow this feature description and it seems important to understand...
what does it mean "Custom Multi-dimension Characters" and how is the pipeline different than the pro ?
can you post a video sample on something that can be done using the pipeline but not in the pro?
I mean - being able to customize a character in pro seems to be working - so how far does it go and what would a Pro user be missing out of compared to the pipeline?
toonarama
toonarama
Posted 11 Years Ago
Visits: 1.3K
I'm sure Peter will answer fully later but the 2 main differences are a) The Pipeline allows you to import a complete self-designed character as a template (ie rather than just replacing individual sprites) which is converted into a character that can use all the CTA features. b) The pipeline allows you to import ICLONE motions (but you also need to have iclone to do this) See here: http://www.reallusion.com/crazytalk/animator/animator_feature_pipeline.aspx
11 Years Ago by
toonarama
Posted 11 Years Ago
Last Active: 16 minutes ago
The two main areas of difference between Pro and Pipeline is in character creation and animation. In the Pro version you can only create entirely new custom characters by replacing sprites. In the Pipeline version you can customize a Flash Character Template that is supplied to enable automatic creation of multi-dimensional characters. So basically if you want to to create a lot of your own custom characters from scratch then the Pipeline method can be a massive time saver over replacing individual sprites in CTA2. However you will need additional software such as Adobe Flash or DrawPlus to use the Flash Character Template. The other important difference is that Pipeline, as toonarama has already explained, allows you to import motion files from iClone in iMotion format. Again this will be a big time saver in animating your G2 characters and opens up a massive library of available animations in one go.
narf2n
narf2n
Posted 11 Years Ago
Visits: 333
thanks for the extra detail and explanation still, I'd love to see it in action to get a better understanding of what to expect, when do you expect to release a video demo / tutorial of the pipeline actions you mentioned? plus, I gather from other questions you will offer an upgrade from PRO for the early birds that jumped on the earlier offer - any idea how much and when it'll be?
adambrannon
adambrannon
Posted 11 Years Ago
Last Active: 10 Years Ago
Visits: 62
narf2n (12/19/2013)
The upgrade path that I was quoted for CTA2Pro to CTA2Pipeline is $69 or $99 if you want to include the upcoming G2 PowerTools. The upgrade isn't posted on the offers page yet, so you'll have to request it in a support ticket, but it is available now. Of course, if you go with the bundle that includes G2 PowerTools, you won't be able to download that until it's released.
brothertcoleman
brothertcoleman
Posted 11 Years Ago
Last Active: 20 minutes ago
Visits: 6.1K
I purchased CTA2 today but I'm unsure of what can open up the Pipeline_Template_and_Tools Folder that came with my download. These are the errors in DrawPlus
11 Years Ago by
brothertcoleman
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K,
Visits: 17.1K
Peter says a DrawPlus compatible file will be available around mid to late January. Jeff
brothertcoleman
brothertcoleman
Posted 11 Years Ago
Visits: 6.1K
So what program are these files for,if not DrawPlus or CTA2?
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K,
Visits: 17.1K
They can probably be used by Flash, SwishMax, etc. Jeff
UglyBaby
UglyBaby
Posted 11 Years Ago
Visits: 64
Question: does every member of the team need to have the Pipeline version? Or can I give Pipeline to my character creator and Pro to my animators and let them open the custom characters in Pro to do their animation work?
