alison26
alison26
Posted 11 Years Ago
Last Active: 11 Years Ago
Visits: 11
I am trying to export my project adn any format I use it says WAV load file error. I have two parts to the project and the second part exported with no prolem. The first part is 27000 frames with a lot of TTS and barely any movement. Help
planetstardragon
planetstardragon
Posted 11 Years Ago
Posts: 11.5K,
Visits: 45.9K
Hi alison, Welcome to the forum! first thing that comes to mind is to make sure that you have a 16 bit 44k wav file - If it's anything other than that you can use a free software like audacity http://audacity.sourceforge.net/ to convert it to a compatible format. Even though it's wav - wav can come in a variety of non standard flavors that are not compatible with most programs. Cheers!
11 Years Ago by
planetstardragon
alison26
alison26
Posted 11 Years Ago
Visits: 11
Im sorry I have no idea what you just said. I only used the Text to speech feature so how would I convert anything? I download audacity but that's about it.
alison26
alison26
Posted 11 Years Ago
Visits: 11
I think the main problem is that my file is to big. If I start deleting audio eventually I get it to export. I have two presentations I made. One was large and one small. The small one converted no problem. I am so confused. Thank you for your help in advance.
11 Years Ago by
alison26
planetstardragon
planetstardragon
Posted 11 Years Ago
Posts: 11.5K,
Visits: 45.9K
ahh, ok, I thought you were importing a file from a 3rd party source. ie - using another program to generate tts - which some of them will output non standard 8bit files. In this case - you may be right with a file being too large and your computer may simply be having a hard time handling it - but that's a one of several things that could cause it. My first guess is that your computer is low on resources. Can you please share your computer specs ? we'd need to go down a list of things that could cause this, starting with your computer / hardware. things that can cause this - older computer with low resources bad audio driver, bad / outdated directx drivers corrupt data
11 Years Ago by
planetstardragon
alison26
alison26
Posted 11 Years Ago
Visits: 11
Well its a brand new computer only two days old. Drove over my old computer so had to buy new one asap. DELL 7537 SpecificationsSpecs: | Details: | Description: |
Warranty Terms - Parts | 1 year limited | |
Warranty Terms - Labor | 1 year limited | |
Height | 0.9 inches | |
Width | 14.9 inches | |
Depth | 10 inches | |
Weight | 5.7 pounds | |
Processor Brand | Intel® | |
Processor | Intel® 4th Generation Core™ i5 | (Also known as the CPU). The part of the computer that interprets and executes instructions. Think of it as the brain of the computer. |
Processor Speed | 1.6GHz (with Turbo Boost up to 2.6GHz) | How fast a computer processor carries out instructions. In general, faster is better, but processor speeds across brands may not be equivalent (i.e., a 3.0GHz AMD processor may not be the same speed as a 3.0GHz Intel processor). |
Battery Type | 4-cell lithium-ion | |
Display Type | High-definition LED-backlit touch screen with TrueLife technology (1366 x 768) | Technology used to display text and images on the screen. Computer monitors are available in 2 types: CRT (traditional tube displays) and LCD (flat-panel liquid crystal displays). Notebook computers, PDAs, mobile DVD players and other devices use LCD screens. |
Screen Size (Measured Diagonally) | 15.6" | Size of the screen, in inches, measured diagonally from corner to corner. |
Cache Memory | 3MB | A small segment of memory that stores frequently used information for fast access by the processor, improving response time. |
System Memory (RAM) | 6GB | The memory a computer uses to run its operating system, applications and active data files. Greater amounts of RAM improve speed and enable more applications to run at once. |
System Memory (RAM) Expandable To | 8GB | Maximum amount of memory a computer can support (as opposed to the amount that comes preinstalled). |
Type of Memory (RAM) | DDR3L | |
Hard Drive Type | SATA (5400 rpm) | Hard drives are classified based on the interface they use to connect to a computer. Common interfaces for internal hard drives include EIDE, PATA (also known as, ATA and IDE), SATA and SCSI. Common interfaces for external hard drives include USB 2.0, FireWire and eSATA. |
Computer Hard Drive Size | 750GB | Capacity for storing programs, photos, video, music and other electronic information. Hard drive capacities range from a few gigabytes to several hundred. |
Optical Drive | Not included | |
Direct-Disc Labeling | No | |
Digital Media Reader or Slots | Yes, digital media card reader | |
Graphics | Intel® HD Graphics 4400 | Type of graphics (video) adapter (usually built into the motherboard), identified by manufacturer and model. |
TV Tuner | No | Enables reception of TV programs. |
MPEG | No | A group of digital video formats created by the Motion Picture Experts Group (MPEG) to compress high-quality video into file sizes small enough to be transmitted over the Internet. |
Built-in Webcam | Yes | |
Modem | None | Device that allows a computer to send and receive information over telephone or cable lines. |
Networking | Built-in 10/100/1000 Ethernet LAN (RJ-45 connector) | Ability to connect to other devices on a network using Ethernet, Wi-Fi (wireless; 802.11), Bluetooth, etc. |
Wireless Networking | Wireless-B+G+N | |
Bluetooth-Enabled | Yes | |
S-Video Outputs | None | Connections that deliver separate color and black-and-white video signals through a single cable. S-video connections provide better picture quality than RF and composite video connections but not as good as component video, DVI and HDMI connections. |
Audio | Waves MaxxAudio | |
PCMCIA Slots | None | Slots in notebook computers that accept credit-card-size upgrade cards. Type I is used mostly for memory, Type II for modem, fax and network cards, and Type III for hard drives. |
IEEE 1394 FireWire Ports | None | (Also known as FireWire, Apple Computer's trademarked name for IEEE 1394.) High-speed connection that supports data transfer rates of up to 400 Mbps or 800 Mbps (depending on port version). |
Parallel Ports | None | Older and relatively slower interface most commonly used to connect a PC to a printer. |
Game Ports | None | Jacks for connecting video game controllers. |
Laptop Weight | Standard (more than 5.5 lbs.) | |
Battery Life | Not available | |
HDMI Output | Yes | |
Blu-ray Player | No | |
Touchscreen | Yes | |
Operating System Platform | Windows | |
Operating System | Windows 8 | The master software that controls hardware functions and provides a platform on top of which any software applications will run. Commonly used systems include Microsoft Windows and Mac OS X for computers and Palm OS and Microsoft Windows Mobile for PDAs. |
Included Software | Pocket Cloud Companion and more | |
ENERGY STAR Certified | No | ENERGY STAR is a joint program of the U.S. Environmental Protection Agency and the U.S. Department of Energy helping us all save money and protect the environment through energy efficient products and practices. |
Best Buy PC App | No | |
Graphics Chip | Intel | |
Backlit Keyboard | Yes | |
Drive Capacity | 750GB | |
Graphics Card | Intel® HD Graphics 4400 |
planetstardragon
planetstardragon
Posted 11 Years Ago
Posts: 11.5K,
Visits: 45.9K
Thank you.... ya ..nice computer, it's certainly powerful enough so we can rule that out! - things that caught my attention the maxxaudio - which is non standard - some non standard audio drivers, 'sometimes' insist on doing things their way and virtually rewiring your system in a way that's not always compatible with other software that use the windows audio routing system - not saying this is the case - but one point of concern that can cause issues. windows 8 - i stuck to windows 7 because windows 8 seems to be a hot mess at times lol. no nice way to say it! this could also be one of those "whats wrong with windows 8 now?!" issues. One thing to check on this is to make sure you have the latest updates installed. other possible causes - -virus - improbable but not impossible. -anti-virus - unlikely - but not impossible - especially if it's set to some paranoid mode - corrupt direct x - improbable because it's a new computer - not impossible because the install could have been bad. - corrupt software install - possible, especially with new computers - I've seen several people post about erratic software issues on first installs on a new computer - and a fresh install fixed it. -Some of these new computers add so much extra software to impress with bells and whistles- that it actually eats up your resources before you get to start any other software, ultimately degrading your computer performance more than helping it.
11 Years Ago by
planetstardragon
vidi
Posts: 10.8K,
Visits: 40.2K
Intel® HD Graphics 4400 Type of graphics (video) adapter (usually built into the motherboard), identified by manufacturer and model. Maybe not powerful enough ?
alison26
alison26
Posted 11 Years Ago
Visits: 11
IS there a way to break down an existing project into smaller ones without loosing anything
alison26
alison26
Posted 11 Years Ago
Visits: 11
whats the best way to export for youtube or any video service to watch online at school.. note still cant export bigger part of presentation.
