iClone Avatar Toolkit2 Release
Posted By Bruce (RL) 12 Years Ago
Rated 5 stars based on 3 votes.
Bruce (RL)
Bruce (RL)
Posted 12 Years Ago
Distinguished Member (68.9K reputation)Distinguished Member (68.9K reputation)Distinguished Member (68.9K reputation)Distinguished Member (68.9K reputation)Distinguished Member (68.9K reputation)Distinguished Member (68.9K reputation)Distinguished Member (68.9K reputation)Distinguished Member (68.9K reputation)Distinguished Member (68.9K reputation)
Last Active: 10 Years Ago
Posts: 518, Visits: 2.0K
The all new iClone plug-in for character creation, Avatar Toolkit2 is here. Avatar Toolkit2 is a complete 3D avatar creation system that allows you to freely design and assemble your own animatable characters. It also comes with an intuitive control system that not only allows you to customize every detail and expression on your character's face, but also determine the way they are animated as well!
With the release of the Avatar Toolkit2, we would like to introduce the exciting ToonMaker pack which provides users with the resources to extend their design options with 4 main cartoon body styles. In the mean time, we have repacked the Monster Workshop pack as well. All Monster Workshop assets are totally compatible with ToonMaker, and can be freely exchanged.
For those of you who already have Monster Workshop, download the Monster Workshop Repack here:
http://file.reallusion.com/ic/c21n22/Motion_Monster_Workshop.exe
http://file.reallusion.com/ic/Puppet_Controller.exe
Please Note: The Avatar Controller (aka Puppet Controller) has been updated on the 3rd December 2013 to correct an issue with auto-blink. Please download again using the link above and re-install.
We also have a series of tutorials for learning Avatar Toolkit, click here to check out all the tutorials.
Note: To use Avatar Tookit2, please update iClone to the latest(V5.51) version first.
What’s New in Avatar Toolkit2
Users who have already purchased Monster Workshop can find the major feature upgrades here.
  • Define Your Own Puppet Accessories with the Avatar Builder.
Previously, users could only puppet accessories included in the Monster Workshop; With the Avatar Toolkit2, you can now import any 3D prop as the puppet target.
  • Puppet Any Prop
Before the Avatar Toolkit2, you could only puppet character accessories. Now, you’re able to attach any prop to your characters and puppet it. Your imagination is the only limit! To make any item puppet-ready, just attach it to the enclosed Dummy Character and then make the dummy itself invisible.
  • Create and Customize Facial Expression Templates
iClone was previously limited to puppet-controlling presets for custom accessories like eyes, brows, and ears. Now you can combine your own custom definitions for each accessory to create and animate your own facial expressions.
Avatar Toolkit2 allows you to animate accessories simultaneously with facial expression definitions taken from the Facial Puppet tool for a complete facial performance in a single pass.
Characters can be either bone or morph-based, giving you a high level of flexibility when adding your own unique target expressions.
  • Set Auto-alignment Definitions
Users now have the ability to save character alignment information in puppet accessories, making your applied accessories literally snap to the correct position of any character models you have input alignment data for.
  • Assign a unique Avatar ID for automatic accessory alignment
To maintain auto alignment data of all avatar toolkit family content, we request that all content developers follow the same Avatar ID naming rule to avoid conflict:  Author_PackName_CharacterName
eg.
RL_ToonMaker_Stout / _Curvy / _Junior / _Athletic
RL_Monster_Indigo / _Cherry / _Grochu
  • Spring and Puppet Animation Capabilities in the Same Accessory
Previously, a single prop could not contain both spring and puppet animation data, limiting flexibility. Avatar Toolkit2 allows you to store both spring and puppet data in the same prop, allowing for more creative freedom in your workflow.
Once you setup a character with assigned accessories, you can use the timeline to switch between physics behavior or active puppet behavior You can also make hybrid animations by puppeteering the accessory root bone while allowing the child bones to be governed by physics, resulting in natural spring and swaying effects.
  • Detach the Puppet Panel from the 3D View and Move it Freely!
Those with low-res monitors or limited screen size, rejoice! Your control panels are limited to the 3D view area no more.
______________________________________
Bruce (RL)
Forum Moderator
Reallusion, Inc.
https://forum.reallusion.com
Threaded View
Threaded View
Forum Post iClone Avatar Toolkit2 Release By Bruce (RL) ( 12 Years Ago )
Forum Post Will this toolkit count toward the $299 amount to receive the free... By VES ( 12 Years Ago )
Forum Post i love this, awesome work, thank you! :w00t: By planetstardragon ( 12 Years Ago )
Forum Post with this toolkit, can i deform a normal prop, or must assign bones to... By guidocornia_20100928110210516 ( 12 Years Ago )
Forum Post Questions for RL... Shall I re-install the re-packed Monster... By RobertoColombo ( 12 Years Ago )
Forum Post [quote][b]RobertoColombo (11/16/2013)[/b][hr]Questions for RL...... By Peter (RL) ( 12 Years Ago )
Forum Post [quote]Shall I re-install the re-packed Monster plug-in provided in... By vidi ( 12 Years Ago )
Forum Post Hello I have installed it and although I have not tested it fully yet... By toonarama ( 12 Years Ago )
Forum Post Worth noting that as far as I can tell you only get the updated puppet... By toonarama ( 12 Years Ago )
Forum Post [quote][b]toonarama (11/16/2013)[/b][hr]Worth noting that as far as I... By Peter (RL) ( 12 Years Ago )
Forum Post You may want to have someone spell check things before getting out the... By Cricky ( 12 Years Ago )
Forum Post [quote][b]Cricky (11/16/2013)[/b][hr]You may want to have someone... By Peter (RL) ( 12 Years Ago )
Forum Post Lol!! :w00t: By planetstardragon ( 12 Years Ago )
Forum Post This is an impressive addition. Very versatile and quite unique in its... By DELETED2 ( 12 Years Ago )
Forum Post [quote][b]Armstrong (11/16/2013)[/b][hr]This is an impressive... By Peter (RL) ( 12 Years Ago )
Forum Post After study the Guide and playing a while to understand how it works,... By vidi ( 12 Years Ago )
Forum Post Hello friends, I loaded my updates of the workshop and the new... By Postfrosch ( 12 Years Ago )
Forum Post Postfrosch There is mismatch between versions of content executable... By rampart ( 12 Years Ago )
Forum Post [quote][b]Postfrosch (11/17/2013)[/b][hr] Hello friends, I loaded my... By Peter (RL) ( 12 Years Ago )
Forum Post Hello Peter, the problem was already solved by Susanne from the... By Postfrosch ( 12 Years Ago )
Forum Post [quote][b]Postfrosch (11/19/2013)[/b][hr]Hello Peter, the problem was... By Peter (RL) ( 12 Years Ago )
Forum Post Hi Fantastic plugin, Avatar Toolkit2!That´s I was waiting since... By alemar ( 12 Years Ago )
Forum Post Had the same problem with missing Toon Maker download link Alemar. Not... By Galfridus ( 12 Years Ago )
Forum Post Geoff You was right! Installed and working like a charm! Thank you! By alemar ( 12 Years Ago )
Forum Post ... By DELETED2 ( 12 Years Ago )
Forum Post A question to RL if I use now for my content Avartar Builder... By vidi ( 12 Years Ago )
Forum Post [quote][b]vidi (11/18/2013)[/b][hr]A question to RL if I use now for... By Peter (RL) ( 12 Years Ago )
Forum Post Hi!(^^)/. I purchased "Avatar ToolKit2". I have a question about... By tq.linux ( 12 Years Ago )
Forum Post with the pair and single Dummy's attached I can not export Your... By vidi ( 12 Years Ago )
Forum Post [quote]The ability to create and customize puppet parts opens a whole... By vidi ( 12 Years Ago )
Forum Post Vidi Good question! I want to know this too... By alemar ( 12 Years Ago )
Forum Post Fun with iClone Blocks . The eyes are 2 Bowls and a Ball :D is such... By vidi ( 12 Years Ago )
Forum Post Ha ha - love it! I guess you could have used the eyes from the... By toonarama ( 12 Years Ago )
Forum Post [quote]I guess you could have used the eyes from the monster or toon... By vidi ( 12 Years Ago )
Forum Post UPDATE : It has now been decided to issue the Avatar Controller as a... By Peter (RL) ( 12 Years Ago )
Forum Post [quote][b]Peter (RL) (11/20/2013)[/b][hr] UPDATE : It has now been... By sjonesdc ( 12 Years Ago )
Forum Post [quote][b]sjonesdc (11/20/2013)[/b][hr][quote][b]Peter (RL)... By Peter (RL) ( 12 Years Ago )
Forum Post whoo! Thank you for the controller!! Now I don't have to sell my... By planetstardragon ( 12 Years Ago )
Forum Post "[b]planetstardragon (11/21/2013)[/b][hr]whoo! Thank you for the... By colour ( 12 Years Ago )
Forum Post [quote]UPDATE: It has now been decided to issue the Avatar Controller... By vidi ( 12 Years Ago )
Forum Post [quote][b]vidi (11/21/2013)[/b][hr]Also if my stuff is attached to the... By Peter (RL) ( 12 Years Ago )
Forum Post I get [quote] a prompt to buy an export license?[/quote] and the... By vidi ( 12 Years Ago )
Forum Post You see the dummys are the culprits ... By vidi ( 12 Years Ago )
Forum Post [quote][b]vidi (11/23/2013)[/b][hr]You see the dummys are the culprits... By Peter (RL) ( 12 Years Ago )
Forum Post I've installed Avatar Toolkit Vol 2 and looking under the... By jlittle ( 12 Years Ago )
Forum Post [quote]Or is it the same as a Structured Single iProp?[/quote] yes... By vidi ( 12 Years Ago )
Forum Post Thank you Peter ! it works now :) By vidi ( 12 Years Ago )
Forum Post If I buy the Avatar tool kit and Monster Workshop now do I still have... By eulersosa ( 12 Years Ago )
Forum Post [quote][b]eulersosa (11/29/2013)[/b][hr]If I buy the Avatar tool kit... By Peter (RL) ( 12 Years Ago )
Forum Post UPDATE : The Avatar Controller (aka Puppet Controller) has been... By Peter (RL) ( 12 Years Ago )
Forum Post UPDATE: It has now been decided to issue the Avatar Controller as a... By brothertcoleman ( 12 Years Ago )
Forum Post [quote][b]brothertcoleman (12/10/2013)[/b][hr]UPDATE: It has now been... By Cricky ( 12 Years Ago )
Forum Post The free Avatar Controller is available here . :) :cool: By wires ( 12 Years Ago )
Forum Post DAZ4 Character - You Can Call Me AL This character uses the... By Cricky ( 11 Years Ago )
Forum Post Can I use the Customizable Puppet Controller to animate Daz characters... By VirtualMedia ( 11 Years Ago )
Forum Post [quote][b]vrtmedia_20090922191445474 (2/7/2014)[/b][hr]Can I use the... By Peter (RL) ( 11 Years Ago )
Forum Post [quote][b]VirtualMedia (2/7/2014)[/b][hr]Can I use the Customizable... By Tarampa Studios ( 8 Years Ago )
Forum Post This is also a very old question you're answering...:P By animagic ( 8 Years Ago )
Forum Post Doh!... *facepalm* I wonder why I got an email alert about it today?... By Tarampa Studios ( 8 Years Ago )
