You probably need to adjust the Z axis positions of your objects.
Even though CTA produces a 2D results, the stage actually has three dimensions.
Objects with large differences in the Z direction will show a separation if you are not dead center to the objects with the camera.
The presentation video should be 1 point behind the screen and the screen 1 point behind the character.
Use the object transform button to see and adjust the Z position of your objects.
Make sure you do this at the first frame.
Jeff
