KraftKakes-2012
KraftKakes-2012
Posted 11 Years Ago
Last Active: 11 Years Ago
Visits: 6
Hi folks. I've been using Crazytalk Animator for a few months now and have done most of the tutorials which are terrific. It was quite a steep learning curve, but I love the software.
My problem is that I cannot import a flash file (swf) to use as a prop. I also use Serif Drawplus and I followed all the instructions to create a keyframe animation, export it as flash etc. My flash animation works everywhere else.
This is what I am doing:-
Clicking on Import Media Clicking on Prop Browsing to my Shockwave Flash File Clicking on OK
Nothing happens.
I'd really appreciate any suggestions on this because I am stumped :-(
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K,
Visits: 17.1K
Watch my tutorial on creating an animated prop. You might see what you are doing wrong. Jeff
KraftKakes-2012
KraftKakes-2012
Posted 11 Years Ago
Visits: 6
Thank you Jeff. I have watched your tutorial very carefully and did everything accordingly, but I still cannot insert my own swf file into CTA. I get to the bit where I have clicked on Insert and browsed to the swf file. I highlight the swf file, click Open and nothing happens. The browse to file window closes and no file has been inserted.
I'm wondering if there is some setting which needs changed? I am using CTA Pro.
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K,
Visits: 17.1K
If you want, send me (pm, email, or post) the swf file and I'll see if I can import it or not. You should also be able to drag and drop the file onto the stage instead of using the import. Jeff
11 Years Ago by
jlittle
KraftKakes-2012
KraftKakes-2012
Posted 11 Years Ago
Visits: 6
Hi Jeff,
That is very kind of you. I'm struggling to see how to attach it via the forum pm/send email options though.
I had actually been going to ask if I could obtain a copy of your pinwheel swf file to try it out on my software!
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K,
Visits: 17.1K
KraftKakes-2012 (10/9/2013) I had actually been going to ask if I could obtain a copy of your pinwheel swf file to try it out on my software!Here are the files. Jeff
KraftKakes-2012
KraftKakes-2012
Posted 11 Years Ago
Visits: 6
Thank you Jeff. I've tried that and unfortunately it doesn't work either. So the issue must be with my installation of CTA Pro? I should have mentioned that my Flash file works fine when I insert it into Powerpoint. It accepts all my other graphic files (well I only really use jpeg & png). I am only experiencing issues with Flash. This is why I wondered if there was a setting or preference that I am missing. ETA - I appreciate your time.
11 Years Ago by
KraftKakes-2012
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K,
Visits: 17.1K
You should be able to import SWF files using either the Std or Pro version. Have you tried importing a static (non animated) SWF file? You will probably need to contact support and see what they say. Jeff
KraftKakes-2012
KraftKakes-2012
Posted 11 Years Ago
Visits: 6
It is obviously an issue with my PC Jeff. I tried creating a static swf file and CTA let me import it, but whilst it showed the frame and listed the file in the Scene Manager, it was invisible!
I installed CTA on my laptop (Vista) and it all works fine. My PC is very ancient and running XP.
Thank you so much for your kind help.
Posted 11 Years Ago
KraftKakes-2012 (10/10/2013) It is obviously an issue with my PC Jeff. I tried creating a static swf file and CTA let me import it, but whilst it showed the frame and listed the file in the Scene Manager, it was invisible!
Thank you so much for your kind help.Please try updating the graphics drivers. Quite often this kind of problem can be resolved by doing this.
