jarronn
jarronn
Posted 11 Years Ago
Group: Banned Members
Last Active: 9 Years Ago
Visits: 499
INTRODUCTION:
If you have any important suggestions for making CTA 2 the best it can possibly be DON'T BE SHY!!
MAKE THEM NOW WHILE CTA 2 IS IN THE DEVELOPMENT STAGE!!!
DON'T WAIT UNTIL IT IS ALREADY RELEASED
FROM SUPPORT:
Hi Jarron,
Thanks for your feedback.
Your suggestions are highly appreciated and will help us to enhance the product. I will pass them to our developers.
You can adjust the left foot using the Body Key Editor (Body tab).
Please feel free to let us know if you have any further questions.
Best Regards, Jana Technical Support Reallusion Inc.
MY RESPONSE:
My suggestions will most certainly make CTA Pro 2 ROCK!!!! I'm really looking forward to an AWESOME UPGRADE!!! You have my money as soon as you guys are ready!!!
MAKE IT AWESOME!!!!!!
Look, I'll be honest. It seems I came along at JUST THE RIGHT TIME to help you guys make CTA Pro 2 TOTALLY AWESOME!!! My suggestions are RIGHT ON TIME. So I say PLEASE take them to heart and fix these annoying problems.
Thanks
__________________________________________________________________________________________
Many of your answers can be found by reading the product manual.
The online manual and the online help are NOT the same thing
jarronn
jarronn
Posted 11 Years Ago
Visits: 499
Dear Jarron, Thanks for your reply. In CrazyTalk Animator each character must have the correct front or side pose applied. If it is Front Image then you must switch to the Front Pose, if it is a Side Image then you must switch to the Side Pose Please refer to CrazyTalk Animator online help as below to know how to adjust, first you may check your character is front or side post then adjust it http://www.reallusion.com/crazytalk/Animator/help/animator/pro/03_Actor/Customing_Your_Actor_With_Actor_Composer/Creating_Character_for_Front_and_Side_Motions.htmFurther Body Adjustments http://www.reallusion.com/crazytalk/animator/help/animator/pro/03_Actor/Customing_Your_Actor_With_Actor_Composer/Further_Adjustment_for_the_Body.htmSince your character is in Side Pose you should only apply Side motions. In your case you can adjust the left foot using the Body Key Editor (Body tab). Feel free to let us know if you have any questions. Best Regards, Jana Technical Support Reallusion Inc.
jarronn
jarronn
Posted 11 Years Ago
Visits: 499
NOTE: I went to the hassle of creating a special version of a video I created just to show support the problem of the painful foot twist I was experiencing with CTA Pro: http://youtu.be/Pvr-ERzDF_UTO SUPPORT: Okay, I discovered a workable solution to this painful twist of the left-foot of a character when switching from a front to a side puppet motion: The problem was I was extending the front of the puppet clip TOO LONG and that made for a painfully long twist of the left foot before it would snap into the new position. The solution is to make that transition as short as possible by only extending the front of the puppet clip as little as possible. Then the foot transitions much more quickly BUT NOT INSTANTLY! It happens so fast that I barely notice the painful foot twist. That's a workable solution for now, but I hope you will address and fix this problem in CTA Pro 2 because it can be very annoying. Thanks
jarronn
jarronn
Posted 11 Years Ago
Visits: 499
TO SUPPORT: MY CHIEF CONCERN is how this problem will translate to a character I create of myself from photos. It seems to me I am going to have real problems with this when I reach that point, no? My guess is that I must have at least two of me. One in a front pose and one in a side pose. Whenever I want to make myself do any side pose movements I switch to the side pose 'me' that was kept invisible. After all, the front pose me is going to be mostly for talking and singing. The side pose will be for silly actions that usually will not require much talk ____________________________
11 Years Ago by
jarronn
jarronn
jarronn
Posted 11 Years Ago
Visits: 499
Nice for them to tell me what I had to figure out on my own AFTER I figure it out, right?
FROM SUPPORT:
Dear Jarron,
Of course you can shorten the transition to make the effect less visible or apply a front and a side character. But you can also simply use the Body Key Editor and rotate the left foot to the correct position.
As I mentioned previously, I will pass on your feedback so thank you for sharing your views.
Please do contact us again if you have further questions.
Best Regards Jana Technical Support Reallusion Inc.
jarronn
jarronn
Posted 11 Years Ago
Visits: 499
MY RESPONSE:
Well, the thing is the left foot SHOULD rotate at the angle a left foot would rotate in such a situation. It should not bend up in a ridiculous painful UNNATURAL position then snap the way it does. This is something that should be fixed and I sincerely hope you will fix the problem as I am looking forward to purchasing CTA Pro 2 and having these problems solved.
What CTA Pro needs is when you create ANY character from photos you create a front and side pose at the time of creation so that whenever your character switches to a side pose all the sprite parts are already in place for the switch and it becomes more natural looking. I'm not ready for that phase of animation yet, but I am getting close, very close.
AverageJoe
AverageJoe
Posted 11 Years Ago
Posts: 2.4K,
Visits: 10.1K
There are multiple threads with multiple suggestions already...
jarronn
jarronn
Posted 11 Years Ago
Visits: 499
wizaerd (9/17/2013) There are multiple threads with multiple suggestions already...Well, that does not necessarily mean the suggestions have reached the core support team. I'm talking about going directly to the source to make your suggestions: http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspxYou blindly assume that suggestions made in this forum automatically are picked up by the core support team. I don't make such blind assumptions. IF YOU WANT TO MAKE CERTAIN YOUR SUGGESTIONS ARE CONSIDERED I SUGGEST YOU GO TO THE SOURCE WITH LINKS TO THOSE TOPIC THREADS AND GIVE THEM THE LINKS. I'm learning more and more that to blindly trust often leads to incredible disappointment. Just yesterday...well...I won't get into that.... _____________________________
11 Years Ago by
jarronn
vidi
Posts: 10.8K,
Visits: 40.2K
Well, that does not necessarily mean the suggestions have reached the core support team. I'm talking about going directly to the source to make your suggestions: I'm a long time User here , therefore I know RL read this forum and makes all our wishes true. For me the Best Company with the ear on the Community.
AverageJoe
AverageJoe
Posted 11 Years Ago
Posts: 2.4K,
Visits: 10.1K
jarronn (9/17/2013)
wizaerd (9/17/2013) There are multiple threads with multiple suggestions already...Well, that does not necessarily mean the suggestions have reached the core support team. I'm talking about going directly to the source to make your suggestions: http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspxYou blindly assume that suggestions made in this forum automatically are picked up by the core support team. I don't make such blind assumptions. IF YOU WANT TO MAKE CERTAIN YOUR SUGGESTIONS ARE CONSIDERED I SUGGEST YOU GO TO THE SOURCE WITH LINKS TO THOSE TOPIC THREADS AND GIVE THEM THE LINKS. I'm learning more and more that to blindly trust often leads to incredible disappointment. Just yesterday...well...I won't get into that.... _____________________________ Uhhh no, I don't "blindly" assume anything. But if you read those threads, you'll see responses from RL that they're read them and submitted them tot he development team.
