Visits: 575
Trying to animate a sprite walking across screen then at the end turning toward camera. I am using 2 sprites, 1 that is a side view and the other that is a front view. I can get the character to walk across the scene ok but at the end am unsure how to substitute the front facing sprite in place of the sidewalking sprite. Hope this is clear. Thanks
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K,
Visits: 17.1K
On the Stage use the sprite editor to switch sprites at the frame(s) needed. Open the sprite editor, select the part to switch the sprite for and select the sprite to use. The sprite must first be imported into the character in Character Composer Mode. Jeff
Visits: 575
Thanks for the quick reply!
