diomkal
diomkal
Posted 11 Years Ago
Visits: 4.2K
Does anyone can give me a good example with handling the camera in CTA? Documentation standard is too low in my opinion. Eg through a space, through example by observing certain elements, accompany a walk ...
jlittle
jlittle
Posted 11 Years Ago
Posts: 1.9K,
Visits: 17.0K
You move the camera using the Camera Transform track just as you would for moving an actor or object around. When in camera REC mode use the Zoom, Move, and Rotate cursor modes to affect your camera movements. Here is an example of what you can do: Jeff
diomkal
diomkal
Posted 11 Years Ago
Visits: 4.2K
Thank you for your answer. This is exactly what your video shows that I want to master. Is it possible for you to explain me step by step what I have to do exactly to have such a result?
Posted 11 Years Ago
Last Active: 10 hours ago
Posts: 22.6K,
Visits: 35.6K
diomkal (2/20/2013) Thank you for your answer. This is exactly what your video shows that I want to master. Is it possible for you to explain me step by step what I have to do exactly to have such a result?If you haven't seen it already, be sure to check out the Camera and 3D View tutorial below. http://www.youtube.com/watch?v=2Ve70HfvYmU The Scene Camera section is from 1:50 onwards.
