Hello, im new to CTA and am in the process of learning the programming for my cartoon. i found that i like the way the characters move better when i import them through the character creator aspect of CTA. i have been using illustrator to create all my vector files and have been exporting them as png files to eliminate the backgrounds. once i set the wire frames and indicate the joint size i bring it to the stage. this is where i have a problem. because they are cartoons i know im going to have to create a library of eyes, mouths and hands to switch in and out in sprite editor. i have been able to select all limbs except the eyes and mouth. it just selects the head as a whole. any suggestions. or is there a better way to import my character as a whole for animation? thanks in advance.
also i assume i will have to draw a side shot of the cartooncharacter and set wire frame at that angle in order to see character move from that angle correct
thanks
