Hi!
A little rpg start. Equip the sword and potion.
I am using the Esenthel engine,
(http://www.esenthel.com/) and 3d models from Arteria3d, Reallusion and 3dfoin.
The music is from Arteria3d and most sound effects from Sounddog.
And a model from Turbosquid. Some trees from Pure3d.
All stuff I used went tru 3DXchange pipeline, even 3dfoin and Arteria3ds models, because the pipeline was able to enhance some some of the models to use the motions layer editor more easily etc.
The rpg is based on src code gotten from the Esenthels author, which I modified to
handle the motions for the chars, (had to adjust for different bones and such) and some other stuff.
The combat system included in the source code is very cool, with ragdoll and "hit" .
Will continue work on this, but like allways, everything took much longer than anticipated.
A little tutorial:
http://youtu.be/tHDvIRl923MHere is the game:
http://lmlsoft.se/Esenthel RPG 2_ICLONEGAME.rarAn instruction:
Download the file ( quite big) unrar it and then unrar the datafile also.
So the exe file should be in a directory with two other directories, a Bin and a Data dir.
(Directly under the Data dir there should be several directories, Anim, Cursor, Enum .....)
The knight is the "main" char, didn't have time to work so much with the others, but they should work too. ( I mean adjust the motions more, etc )
Best Regards
Lukas
12 Years Ago by
lukas.lundberg
