Mauidelite (5/27/2012)
But the 2nd problem I'd like advice about is dealing with the teeth. The points for an open mouth are hard to control, so I've used the points for a closed mouth on this one (see attached). What method would you suggest?
Thanks,
LauriHi Lauri
You shouldn't really have any problems using the open mouth points. Just remember that the yellow points are for the upper lip and the white points for the lower lip. It's always best to zoom in close when adjusting the points for greater control.
There are no rules about which method you use though. You can use close mouth points as you have shown, but if you want to add custom teeth to your character then you will need to use the open mouth points.
