The Facial Expression Clips are supplied as Motion Clips in CrazyTalk 6.
Once you have added some speech to your character switch to Script - Timeline. Then in the top right you will see the Motion Clip tab. Select this and you should see the Facial Expression Clips listed as shown below. Finally just drag the required clip onto the Timeline. Hope this helps.
