SOLVED.
A bunch of steps....
* Create a prop for your logo by dragging the logo image onto the stage
* Select the character whose torso you want to put a logo on
* Press the Character Composer button
* You can see the prop in Character Composer even though you can't see it in Stage Mode
* Place and size the prop (logo in my case) on the character's torso
* Hide or delete any other sprite body parts so you have just the torso showing without any other sprites touching it
* Make the torso bigger, about three or four times the size (as the actual size won't be big enough to import later on for some reason)
* Take a screen print (I used alt-PrintScreen)
* Exit the Character Composer without saving your changes
* Use an image editor to create and edit the torso image you will replace later. I removed everything in the PrintScreen image except the torso. The background needs to be transparent. I saved my image as a .png
* Select the character again in stage mode
* Click on the torso
* Click on the Sprite editor button
* Replace the torso image with your new one.
* Position and size your new torso to fit accordingly
* Press the Back to stage button and save your changes.
Hope this is helpful for others.
12 Years Ago by
HatHead
