rfacko (4/30/2012)
I was glad to see 5.21 update and installed. Since I updated to 5.2 I have been unable to run Mocap. Tech support has been trying to find a way for me to install so that my Device Manager recognizes my Xbox 360. They insist that I have remnants of past drivers lurking on my hard drive but I have no idea how to find or remove them. They suggested I contact Microsoft. No thanks. That quagmire is a nightmare. Does anyone, ANYONE at all, have ideas, suggestions, etc? I refuse to blame it on the fact that Kinect for Windows is now the way to go -- I purchased the Xbox 360 the moment the the first Mocap became available. It has worked fine. Oh, yes. I do have a new computer with Windows 7 Professional.
Hurting in Florida
Hi rfacko,
It's possible that your system contains phantom device drivers. Phantom device driver references are essentially drivers which are present on the system but are not displayed until the device is physically connected - the most common types are USB-based.
Phantom devices can cause all sorts of issues including display adapters not being recognized, usb devices failing to initialize, etc. The most efficient way of cleaning phantom device drivers is to display hidden devices and uninstalling them. Once the phantom devices are uninstalled, the system must be restarted.
Assuming your O/S is Windows 7, you must set the DEVMGR_SHOW_NONPRESENT_DEVICES system environment variable. Once set, you can invoke the Device Manager and select the Show Hidden Devices from the View menu. Use the Windows Logo + Pause/Break key combination to display the computer system information; from there, you can select Advanced System Settings and Device Manager.
Win2K/WinXP/WinV/Win7: http://support.microsoft.com/kb/315539
Afterwards, look at this URL to identify and remove any Kinect related drivers:
http://faq.reallusion.com/index.php?action=article&cat_id=011001006002&id=493&lang=
Once the phantom device driver references are removed, ensure that you have uninstalled all OpenNI, PrimeSense, Microsoft Kinect packages via Programs And Features. During this process, ensure that the Kinect device is not physically connected to your system.
Cheers,
REF Url's
http://faq.reallusion.com/?action=category&cat_id=011001006
http://www.reallusion.com/iclone/help/iclone5/PRO/default.asp?page=08_Animation/Device_Mocap/Using_the_Device_Mocap_Panel.htm
__________________________________________________________________
DELL Precision T7500 & Precision M6600
Dual Quad Core XEON 2.13 GHz, 12 GB RAM, 1 TB HDD's
nVidia Quadro 5000 (2.5GB RAM), Driver 320.49 (2013.07.03)
Windows 7 Ultimate (64bit)
Dual 22" LCD Monitors
iClone 5.5 Pro, 3DXchange 5.5 Pipeline, CrazyTalk & Animator Pro
Autodesk Entertainment Creation Suite 2014
Adobe Production Premium CS6
12 Years Ago by
hgagne
