Ajit.Sirohi (11/11/2011)
Not clear. If I buy another copy of Crazy Animator Pro then I can install the two copies on 4-machines ( 2-installations per copy.) Will the same copy of Powertools work on all the 4-machines.
Also, does the registration of Powertools have to be to the same email account as CrazyTalk Animator. I seem to have registered to a differrent email. How can I correct this if this is going to cause problems.Each copy of CrazyTalk Animator can be installed on two computers. However it can only be used on one at a time. If two people are to use CTA at the same time then further licenses are required.
You will be able to install Power Tools for each installation of CrazyTalk Animator but it is vital for both Power Tools and all copies of CrazyTalk Animator to be registered to the same account.
If you have used two different email addresses for CTA and PowerTools then you may run into problems as your email address is linked to your account. If you do have problems I would advise contacting Customer Support using the link below. They will be able to help you resolve any email conflict.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
