| | | Newbie
Group: Last Login: 1/2/0001 12:00:00 AM Posts: 0, Visits: 0 |
| I have instaled CrazyTalk 4.5 on my Win98SE PC.
The install went fine but after starting the program when I play the default model the sound comes in first and there is a milisecond delay of lip-sync.
Its like watching a badly dubbed chop-socky movie.
I thought it was because I only had DirectX6 on my PC so I installed DirectX8 and I have the same problem.
I played it in my WinXP PC and the mouth moves with the voice but not in Win98SE. I installed it on my Dell notebook which has Win98SE too and its the same thing.
Anyway I don't think this is workable if the playback mouth motions are always is always off so... Does Crazy Talk work with win98SE? |
| | | | Newbie
| Do your Win98SE pc's meet the minimum system requirements? This could be the problem if they do not.
You can check the minimum requirements here:
http://www.reallusion.com/crazytalk/ct_requirements.asp
As always try to make sure the audio drivers on the Win98SE machine are the latest possible.
Peter Edwards (movicomuk) Moderator |
