Moving Content From iClone2 to iClone3
Moving Content From iClone2 to iClone3Expand / Collapse
Posted 9/11/2008 3:55:45 PM
Last Login: Yesterday @ 11:51:21 PM
Posts: 3,801, Visits: 6,294
If you had previously been running iClone 2.5 and had custom and installed content packs you may be wondering how you can get all your old content into iClone3. Well if you know how to drag and drop in Windows Explorer it can be done in a few minutes because both programs use the same file folder structure.
Just copy the content from the iClone2 folders directly over to the same named folder for iClone3. For example Props -> Props, Motion -> Motion.
Purchased Content Packs are installed in the locations below:
C:\Program Files\Reallusion\iClone 2\Template\iClone Template\
or
C:\Program Files\Reallusion\iClone 3\Template\iClone Template\
and your own Custom Content can be found in:
Windows XP
C:\Documents and Settings\All Users\Documents\Reallusion\Custom\iClone 2 Custom
or
C:\Documents and Settings\All Users\Documents\Reallusion\Custom\iClone 3 Custom
Windows Vista
C:\Users\Public\Public Documents\Reallusion\Custom\iClone 2 Custom
or
C:\Users\Public\Public Documents\Reallusion\Custom\iClone 3 Custom
Make sure you have backups of your content as a precaution. Also use Copy rather than Move just in case something goes wrong.
Peter Edwards
Post #9715
Posted 5/24/2009 4:36:43 AM
Newbie
Last Login: 3/10/2010 8:40:57 PM
Posts: 10, Visits: 40
Does this method still work? I have been searching this forum for any mention but I can't find the same template and sample project files and library items in my iClone 3.2 that were in my iClone 2.5. Have I installed something wrong?
Post #20457
Posted 5/24/2009 7:15:06 PM
DonaldC203 (5/24/2009)
If you wish to copy content you installed for iClone 2.5 to iClone 3.2 then you can copy over the content using the locations listed in the top post as a starting point. The folder structure used is very similar between both versions.
So for example you would use Windows Explorer, locate the Props folder of iClone 2.5 and copy all the contents over to the Props folder of iClone 3.2. You can then repeat for characters, accessories, motions etc.
Peter Edwards
Post #20474
Forum Moderators: Visconti, Peter Edwards, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 6:20pm
Execution: 0.219. 11 queries. Compression Enabled.
