| | | Newbie
Group: Last Login: 1/2/0001 12:00:00 AM Posts: 0, Visits: 0 |
| hey everyone just wondering if anyone knows a site were i can download crazy talk voices if you do plz post the link here...
thnx |
| | | | Newbie
| Any WAV file can be used for CrazyTalk as long as it's in PCM http://en.wikipedia.org/wiki/Pulse-code_modulation when saved. You can also 1. use a microphone and record your own voices; 2. Prepare a script and have others read parts for you. 3. Use a voice changer and save it for each character.
So basically any recording that can be saved as a WAV file can be used, and it may be that there are some voices out there you can use, but there is always your own voice and variations of it. It gives you what you want in the pace and text you want.
You also have the option of text to speech which is already available in the Crazytalk software as an option, you can buy additional voices to use under other labeled software and they run approx. $40.00 to $400.00 or more.
Other than that you can hire someone to do the voices for you.
Hope that clears some things up and helps a bit.
http://www.coolclones.com http://www.coolcreators.org/store
Cricky |
