Character overshoots end of path
1234>>>
Character overshoots end of pathExpand / Collapse
Posted 7/30/2011 2:28:55 PM
Last Login: 2 days ago @ 3:39:06 PM
Posts: 1,084, Visits: 4,122
It's been a long time since I've done any iCloning, and so I'm experimenting with very simple stuff.  I have a character, a bench, a path, and a "sit here" AML template.  I right click the character, choose move forward then click the first node of the path.  And walah, he moves right along the path.  But he overshoots it by a considerable margin.  Is this expected behaviour with paths, and I have to compensate by altering the path, or should they in fact stop at (or extremely near) the end point of the path?
Post #88810
Posted 7/30/2011 4:33:10 PM
Last Login: Today @ 5:16:22 AM
Posts: 2,621, Visits: 4,394
wizaerd (7/30/2011)
1) Drag the Previewscreen Timeline Scrubber to end of Path
2) Enter 100, in "Position"
3) Play-back. Character should stop at end of Path.
Anyone-else?
Visit www.pinheadhq.com , to read about Pinhead's exploits & view his Clips. Join-in the Projects &/or Submit a "Fun" Clip, having fun yourself.
System Specs:
Quad Core i7 960 3.20 GHz HT CPU (8Threads) on Asus P6X58D-E MOBO. 6GB Kingston HyperX DDR3 Triple Channel 1600MHz RAM, AMD/ATI Radeon HD 5770 1GB Video Card, 2 X Western Digital Caviar Black 7,200rpm 6GBs 500GB internal HDDs & 1 X 500Gb Seagate FreeAgent externalHDD for system Backups
Post #88812
Posted 7/30/2011 5:05:32 PM
colour (7/30/2011)
wizaerd (7/30/2011)
I don;t suppose you'd care to prvide any more detail?  Such as enter 100 where?  Where is this position entry field?  SHould I have the character or the path selected?  If I have the path selected, I see no Position filed (seen screenshot 1).  If I have the character selected, the Postion field isn't editable because I didn't choose the Pick Path option, I right clicked told the character to Move Forward and then clicked the first point of the path. (see screenshot 2)
Anyone-else?
You know what happens when you assume, right?  Assuming that not everybod is as brilliant as you, and giving vauge instructions isn't really helpful.
  Post Attachments
Post #88813
Posted 7/31/2011 2:39:14 AM
FWIW - My "Brilliance" is at the same level as your's
Re; My "Helpfulness", I suggest you read my over 8,000 Posts helping others in the Pinnacle Studio Forum.
1) Select Character
2) Select Animation Tab
3) Select Create Path
4) Create Path
5) Deselect Path Tool
6) Select Character again
7) Select Pick Path
8) Move Timeline Slider
9) Enter 100 in Position - See Attached Image.
BTW - There's an excellent Video Tutorial by Kurzal, using a Prop, which is self-explanatory.
System Specs:
Post #88839
Posted 7/31/2011 11:53:43 AM
Doing it this way is problematic.  First, the character snaps to the beginning of the path - undesirable.  Secondly, the character doesn;t actually walk along the path, they merely move along the path (glide) - undesirable.
In the manual it clearly states, create a path.  Right click on the character and choose Move->Walk Forward, then click the beginning of the path.  Hence the character walks along the path.  There is no Position field to enter.  All I want to know is, using this method as outlined in the manual, how to make my character actually stop at the end point.
http://www.reallusion.com/iclone/Help/iClone4/Pro/08_Animation/Path/Character_Picking_Path.htm
it's also outlined in the iClone video (at about 2:50) http://www.youtube.com/watch?v=Sduaq3-VOrM&playnext=1&list=PL8E7CBE3691A26EF3
Post #88887
Posted 7/31/2011 3:15:54 PM
wizaerd (7/31/2011)
I would have thought a note of thanks from you for the time & effort I've spent in Replying to your Post, when no-one-else has, so far, would have been in order. Apparently not.
A view that's been Posted many times by the Forum's Experts (Which I'm not), whov'e spent some considerable time & effort helping other Forum Mambers, with precious little thanks
"Manners maketh Man"
The Route & Screenshot I posted, works ok here & for others, apparently.
ADDED -You might like to look at Crickey's Reply in this Thread; http://forum.reallusion.com/Topic88362-86-1.aspx
System Specs:
Post #88910
Posted 7/31/2011 6:05:53 PM
Last Login: Today @ 12:26:10 AM
Posts: 2,245, Visits: 6,427
Post #88917
Posted 7/31/2011 8:02:58 PM
colour (7/31/2011)
wizaerd (7/31/2011)
Had it actually been helpful, and answere the actual question instead of telling me to do it another way, another way contradictory to the instructions in the manual, pehaps I would've given thanks.  Instead of help, all I really got was attitude.  So thanx for that.
Post #88922
Posted 7/31/2011 8:05:34 PM
sw00000p (7/31/2011)
Wizaerd,
OVERSHOOT:
* The overshoot occurs when the {ActionRadius} is incorrect!
* Start with (80 centimeters) and go from there!
Alternative:
Use a (poshelper) to controll character movement!
No Sir, I'm not going to explain to a (Senior Member) how to adjust AML!
... And..... COLOUR WORKED HARD TO HELP YOU!
sw00000p
Forget it, I'll figure it out on my own.  I merely came here to ask how to accomplish something clearly documented in the manual, that didn't give the expected results.  I didn't come here looking for attitude, but it's precisely what I got.  Cocky, arrogant attitude.
Anybody else?
Thats the arrogant response I got.  And instead of helping me out with the clearly documented instructins as outlined in the manual, I was told to do it some completely, and less convienent way.
As I have already stated, by wating iClones tutorials and in reading the manual, I am doing it it the prescribed way.  It is not necessary to Pick Path.  There are many advanatages of doing it the way documented in the manual.  I'll just have to live with the fact that it overshoots.
Post #88923
Posted 8/1/2011 2:43:03 AM
IMO, "An Innocent Bystander" (Legal Term), having read This Thread, would deduce that it's in fact yourself who has a "Cocky, arrogant attitude".
As I recall (Correctly/incorrectly), that's the way described in Kurzal's excellent Video Tutorial.
Since you're not prepared to even attempt to fix your problem by applying the fixes provided, one can only assume that you're a time-waster
There are stronger words I could use to describe yourself, based on your responses, but they would breach the Forum's TOS. Maybe you should read them!
System Specs:
Post #88938
1234>>>
Forum Moderators: Visconti, Peter (RL), julia - RL
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 5:53am
Execution: 0.296. 12 queries. Compression Enabled.
