CRAZY TALK 5 WISH LIST
CRAZY TALK 5 WISH LISTExpand / Collapse
Posted 8/24/2008 5:45:48 AM
Last Login: 12/13/2009 5:41:01 AM
Posts: 27, Visits: 50
1. The option to SAVE as well as the current 'SAVE AS' (which is labelled as simply 'SAVE' - but is really a SAVE AS option).
2. Better control of the the Timeline marker - the mouse must be positioned with some precision to avoid 'dragging an area' instead of simply scrubbing the timeline.
3 The ability to remove randome movements of the face during editing (they confuse what is actually on the timeline) Note: This is probably already an option - I just haven't found it yet. !!
4. I'd like to see more - or different - moutrh shapes 'clues' for speech. The 'automatic' mouth adjustments for an added waveform etc can be pretty inaccurate, and it seems to me that many shapes are conmstructed by using several of the 'basic' mouth shapes. In fact, the mouthing expressions used diring the 'test' (in particular, for the vowels - 'A, E, I, O, and U' ) are exfcellent, but don't seem to be duplicated by the phenome patterns given. They obviously have been created wsith these - so I'd like to see how!!
5. The ability to resize some of the screen - in particular, the timelines - to occupy more of the screen. I use a dual monitor system and split the display over two screens, but it is not possible to extend the timelines vertically, so each property line can be seen clearer.
In spite of all this, an excellent program!!
Post #8630
Posted 8/24/2008 7:38:08 AM
Group: Senior Forum members
Last Login: 2/26/2010 7:59:50 PM
Posts: 31, Visits: 396
mike (8/24/2008)
I find it!! check off the Standby Motion checkbox on the Model>Facial Profile Style
Post #8643
Posted 8/24/2008 2:17:08 PM
Excellent! Thanks. That's one off my wish list (I'll have to think,of another now... )
Post #8658
Posted 8/24/2008 10:52:00 PM
Last Login: 3/18/2010 7:36:11 AM
Posts: 760, Visits: 1,821
Thanks for sharing this idea.
I also move this thread into CrazyTalk forum.
Thanks
Visconti
Visconti
Forum Moderator
Reallusion, Inc.
http://forum.reallusion.com
Post #8675
Posted 9/18/2008 3:55:57 AM
Veteran
Last Login: Yesterday @ 8:02:18 AM
Posts: 174, Visits: 699
I've just purchased CT5 - only issue so far I have with it is it doesn't fully integrate with iClone.
What I mean is you can't import an iClone character into CT5 to create your animation scripts. It's difficult to fine tune expressions for a specific face created in iClone, because the control points on the CT5 character that the script is being created isn't going to be the same as the iClone character. So when you apply that script to the iClone character, it may not accurately animate the same way you it intended it to.
What I'd like to see in a future release, is if you purchase CT5, it should install as an extension integrated into to iClone and you should be able to be able to create the facial animations within iClone on your iClone character rather than having to run a standalone program, save the script and then import it into iClone. That way you can instantly see the effects the facial script will have on your iClone character, and can tweak it accordingly to achieve the desired effects.
_________________________________________________________
Post #9869
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 4:39am
Execution: 0.203. 11 queries. Compression Enabled.
