3ds Max R9 plug-in released
<<12
3ds Max R9 plug-in releasedExpand / Collapse
Posted 1/26/2009 5:12:49 PM
Last Login: Today @ 3:37:54 PM
Posts: 3,319, Visits: 5,635
yanfed (1/26/2009)
(May be) stupid question: there 4 foulders after unzipping , which one is for Max9? I suppose it's R9, but am not sure....
You are correct, the R9 folder is for 3DS Max 9 (not 2009).
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #14589
Posted 2/20/2009 10:32:57 AM
Veteran
Last Login: Today @ 1:59:44 PM
Posts: 106, Visits: 555
hello
there is no instruction, how to install the plugin
http://developer.reallusion.com/whitepaper/iClone3%20Max%20Plugin%20Quick%20Guide/iClone3%20Max%20Plugin%20Quick%20Guide.htm
this link does not work
hjw
Post #15620
Posted 2/20/2009 11:49:27 AM
Group: Senior Forum members
Last Login: Today @ 4:30:18 PM
Posts: 837, Visits: 3,952
Hi, Here's where you put it.
Make sure you have the iClone .dle in the Max 'plug-ins' folder and you have placed the iMagick.dll inside the 3DSMax7(6)(8) folder.
Hope this helps.
Shy
Post #15623
Posted 2/21/2009 5:10:54 AM
Veteran
thank you ,
but what about the files in the folder [RLMaxExp]
copy this folder also to the folder Plugins ?
hjw
Post #15646
Posted 2/21/2009 6:07:19 AM
It goes in the 'plugins' folder.
Shy
Post #15647
Posted 2/21/2009 4:07:20 PM
Veteran
thank you
it works fine
hjw
Post #15672
Posted 6/20/2009 2:57:39 PM
Veteran
Last Login: Today @ 12:50:42 AM
Posts: 266, Visits: 771
I'm trying to sort this out...  Before I spent any money I want to make sure of a few things...
If I understand correctly, the 3DS max plug-in is 32-bit and requires a 32-bit 3DS Max installation. It will work for 3DS Max R8, R9, 2008, and 2009.  Would it work for 3DS Max 2010?
I believe it is possible to install 3DS Max 32-bit under a 64-bit OS (I have Vista 64-bit).  Does anybody know if this is correct?
Finally, is there a change of a 64-bit of the plug-in being developed?  It's kind of a waste to run a 32-bit version of an app if a 64-bit version is available and you have a 64-bit OS.
Post #21596
Posted 11/5/2009 12:05:06 PM
Veteran
Last Login: Today @ 10:31:12 PM
Posts: 158, Visits: 800
yes you can use max 32 bit under 64 bit version. If you use vista you need the upgrate to work under vista.
Post #31135
Posted 11/5/2009 7:18:33 PM
Veteran
Thank you!  That took a while to get answered...
Post #31174
Next Topic »
<<12
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 11:59pm
Execution: 0.172. 11 queries. Compression Enabled.
