changing custom folder
12>>
changing custom folderExpand / Collapse
Posted 8/16/2008 11:34:26 PM
Group: Senior Forum members
Last Login: Today @ 5:32:54 PM
Posts: 1,349, Visits: 6,185
i wanted to move my custom folder to a different drive after iclone 3 install - wondering if anyone knew whether we can change ini file or registry to point to a different custom folder other than the one used during the install process
Statements made above may be fact based or are my opinion only which are sometimes right but are never wrong
www.animatechnica.com
Statements made above may be based on fact or my opinion only which are sometimes right but are never wrong
Post #8164
Posted 8/20/2008 2:07:47 AM
Last Login: Today @ 4:16:23 AM
Posts: 760, Visits: 1,819
Hi, Aknzrdude
You can go to "Run..." and input "regedit" to oprn the window "Registry Editor".
You can find iClone3 in the left-nav, and change the path in the highlighted items.
I hope this info helps.
Thanks
Visconti
Visconti
Forum Moderator
Reallusion, Inc.
http://forum.reallusion.com
Post #8395
Posted 8/20/2008 2:41:54 AM
perfect! thanks for the tip
Post #8397
Posted 8/22/2008 2:49:53 PM
Last Login: Yesterday @ 5:21:20 PM
Posts: 625, Visits: 1,269
Recently P. Edwards told me my suggestions were not "normal computer practice"
Now We can read here, the way to change the custom folder is by... ¡Using regedit and changing entries there!
My goodness! Is this "normal computer practice"?
Come on RI readers to this comment.... Create a configuration utility or build it into next updates!
That would be "normal computer practice"
Mike
Mike Aparicio Reallusion Certified Content DeveloperReally Certified
Apparition's Good Friends Gallery - Lucky of me!
Post #8539
Posted 8/23/2008 10:57:42 PM
Last Login: Today @ 4:41:01 PM
Posts: 3,791, Visits: 6,271
Mike Aparicio (8/22/2008)
Mike
Hi Mike,
I have replied to your other thread re the "normal computer practice" post. Please find my explanation below.
http://forum.reallusion.com/Topic8490-83-1.aspx
Thanks.
Peter Edwards
Post #8619
Posted 5/27/2009 1:01:24 AM
ok i just built a new system on Vista 64bit, installed IC3 but now i want to change the custom folder to a different drive than the default -
i open up regedit - got to Current User / Software / Reallusion \iClone \ 3.0\
but there is no entry for IC3 custom folder - so i add a new string value, enter Custom Data - and point to my drive location - however this does not seem to work
 any tips on how to edit the custom folder location?
Post #20556
Posted 5/27/2009 10:07:03 AM
aknzrdude (5/27/2009)
Go to HKEY_LOCAL_MACHINE instead of CURRENT_USER. The Custom Data location should be listed there. Remember to change Custom Motion and Shared Custom too. Changing them to the correct locations should do it.
Peter Edwards
Post #20563
Posted 5/27/2009 11:11:27 AM
thanks Pete - i actually started out with the HKEY_LOCAL_MACHINE but did not find an entry for Reallusion - so instead went to CURRENT_USER where there is a Reallusion entry
so if there is no Reallusion entry in Local Machine - any ideas/tips?
Peter Edwards (5/27/2009)
i open up regedit - got toCurrent User/ Software /Reallusion \iClone \ 3.0\
but there is no entry for IC3 custom folder - so iadd a new string value, enter CustomData - and point to my drive location - however this does not seem to work
Go to HKEY_LOCAL_MACHINE instead of CURRENT_USER. The Custom Data location should be listed there. Remember to change Custom Motion and Shared Custom too. Changing them to the correct locationsshould do it.
Post #20566
Posted 5/27/2009 2:35:20 PM
I'm using Vista 32bit, not 64bit and HKEY_LOCAL_MACHINE is always where all the folder location settings for iClone are stored. It seems strange you can find no trace of Reallusion there.
Have you tried doing a search of the registry (CTRL-F) to see if you can find it listed elsewhere? Also have you restarted the computer since installing iClone and tried running it with the current default settings? Try this and then check the registry.
Good luck.
Peter Edwards
Post #20579
Posted 5/27/2009 3:02:26 PM
will try these suggestions - thanks!
Post #20581
12>>
Forum Moderators: Visconti, Peter Edwards, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 7:28pm
Execution: 0.172. 10 queries. Compression Enabled.
