Veteran
Group: Forum Members Last Login: Today @ 3:48:38 AM Posts: 298, Visits: 802 |
| Junior: Yes I installed the new driver first. But still no functionality.
About copying the 3D TimeSquare pack to the Prop folder in IC3 is in my mind SHIT!
If I understand things correct, the installer ask you if you want to install under IC2 or IC3 and that should work!
I "Imported" the 3D scene from IC2 to IC3 that should work!
To be forced to take a 3D environ and make it a prop is based on IC2:s limitation of Prop, very, very weak and a POOR solution in my mind. IC3 should be bugg-corrected and supplied to some of us as BETA testers. In my mind Reallusion has failed miserably with BETA testing and should now use the force of active users to get to terms with the problems.
But YES!!!
It is good that if we as users want, we can actually make things work... But With this BUG and the pure CRAP animation that looks like the AVATAR:s have a stick up their bum AND they can't lower their arms AND the KNEE joint will not bend..... IT IS A JOKE!!!!!!!
I am a Software developer myself and this is a half ready thing and it definitely needs a LOT of debugging before it is reasonable to call this IC3 ready for customers... I believe that some PR should be issued for some of us and I can not understand why Reallusion:s developers was so stupid they did not include the old RENDER engine into IC3 allowing us with to old drivers and/or Graphics card:s be able to testrender and see most of what we dreamt about since months ago.. If you look at most of the content it is reworked IC2 stuff almost all of it. The persona is nothing else but a template of motions that is specific for let's say a dancer or a fighter... but in it self it is IC2 technology. Why not also the RENDER engine????
In my mind this messing around finding non standard ways to make things work is so 70:s and stinks of greed and incompetence, I thought that Microsofts cheat OP:s had shown that this philosophy does not work... and it reflects very bad on the product, the company and the future trust!
Get a grip REALUSION!
A very irritated Gorz
White Tiger Web Shop found at http://www.gallery.swcab.nu/
Animated ANIMALS, live props, live animals, ordinary props, music, freebies and much more....  |
| | | | Senior Member
Group: Forum Members Last Login: 5/2/2009 7:18:41 AM Posts: 60, Visits: 243 |
| Yes I found most of the 3d scenes from IC@ have to be put into the props folder now. They seem to load fine as a prop.
| | | | Senior Member
| | Sorry that should read , 3d scenes from IC2 should be put into the props folder of IC3. That is probably needed for any 3D scenes purchased now that were made for IC2. The time square scene possibly. |
