Linking Access using 3dxchange
Linking Access using 3dxchangeExpand / Collapse
Posted 7/9/2008 9:04:15 PM
Last Login: Today @ 2:23:53 PM
Posts: 49, Visits: 171
Ive notice that its much more difficult to link accessories that you download from Google warehouse using 3dxchange. For instace when adding a sword to my scene I have to edit almost every keyframe to alig the sword correctly to a body part. Is there an easier way to do this?
Post #5548
Posted 7/9/2008 11:37:27 PM
Skype ID= learn.iclone
Group: Senior Forum members
Last Login: Today @ 12:59:26 PM
Posts: 563, Visits: 2,363
The easiest way I've found is a 3 step procedure.
1. Load a current Accessory from iClone that you know is positioned correctly into 3dXchange.
Note it's position visually inside the view window and what body part it is attached to inside iClone..
2. Download your model intended to be used as an accessory from the Google SKP warehouse.
You will note it is way off in position from the previous load of a properly aligned accessory in the library.
3. Re-Align the best you can visually from the working models positioning noted in step one.
Export to iClone and resize to fit after positioning it in the same hand for instance that the step one model was in.
You may need to see how it relates to the dummy model inside 3dXchange, but it usually isn't necessary.
It works for me anyway.
Post #5550
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 4:07pm
Execution: 0.156. 11 queries. Compression Enabled.
