Hair Models
Hair ModelsExpand / Collapse
Posted 6/19/2008 1:13:40 PM
Last Login: 10/12/2008 6:16:42 AM
Posts: 22, Visits: 94
Can I use the hair models from this website:
http://www.daz3d.com/i.x/marketplace/0/-/?&_m=d&trid=267458128
to import into iClone to create more hair options? Will I need to use 3Dxchange in order to make it work? Thanks.
swilbert
Post #5198
Posted 6/19/2008 3:25:51 PM
Posts: 3,319, Visits: 5,635
Yes you can use hair models from Daz or Renderosity. It will require the model to be imported with 3DXchange (or 3DS Max) first.
A word of caution. Some hair models from Daz are high polygon, complex models which may impact on performance in iClone. I have found the simpler hair models work fine but it is a trial and error process so be aware that not every hair model will work well. If you scale and position the hair roughly in 3DXchange first, it will only require small adjustment in iClone to get a good fit.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #5199
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 7:20am
Execution: 0.234. 10 queries. Compression Enabled.
