Complete Transparency
Complete Transparency Expand / Collapse
Posted 6/19/2008 7:25:31 AM
Newbie
Last Login: 10/9/2008 2:03:34 AM
Posts: 6, Visits: 19
Im new to iclone and i like it. Im really in to gif animation from iclone!
As i can see there is a standard gif exporter in iclone. My problem is
the transparent is not complete. That means even i set it to
Transparent from advance function i can stil see a very thick border in the
output file. Because of that i cant put those created gif animation files
to my websites!
My only solution is open each image gile from pohotoshop and erase that
layer by manually. But it is very time consuming!
plz let me know If any one know any solution to this !
Post #5189
Posted 6/19/2008 8:29:22 AM
Group: Senior Forum members
Last Login: Yesterday @ 10:09:27 PM
Posts: 321, Visits: 928
This may sound stupid, but you could try setting the background in Iclone to the same colour as the background on your website. Maybe it would be less noticeable - I will test this.
The transparency doesn't work very well. But rendering without transparency on a white background, and then adding to a website with white background worked fine. I suppose as long as you can match the Iclone background with the webpage background, this is a workaround. However, if your webpage has some kind of design background on it, then I guess this wouldn't work.
Alley
Post #5192
Posted 6/19/2008 8:00:39 PM
Newbie
Hi Mate,
Thanks for your reply.
That solution will not work to my website. My website is not static.
Characters moving on a virtual worls.
So i need a complete transparentcy.
PM i will give my website. dont like to post links here
But thank you very much for your reply.
cheers
Post #5203
Posted 6/19/2008 9:31:27 PM
Group: Moderators
Last Login: Yesterday @ 11:10:37 PM
Posts: 1,621, Visits: 2,795
gayanfx (6/19/2008)
Altough the transparent is not complte. That means even i set it to
Transparent from advance function i can stil see a very think border in the
to my websites!
layer by manually. But it is very time conduming!
Are you taking the tick out of Anti-Aliased?. When exporting GIF images with transparency, turning off the Anti-Aliased option will produce cleaner edges.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #5205
Posted 6/19/2008 9:58:06 PM
Newbie
Yes it is working. Thank you very much. i didnt realized it.But when i remove reinitializing the image get bit messy when we select
small resolution 200x200. But im going to make it bit bigger and render without it.
Thanks
Problem solved!
Post #5206
Permissions Expand / Collapse
All times are GMT -7:00, Time now is 3:13am
Execution: 0.203. 15 queries. Compression Disabled.
