Setup.exe stopped working in Vista with Crazytalk 5.0
Setup.exe stopped working in Vista with Crazytalk 5.0Expand / Collapse
Posted 5/5/2008 11:21:23 AM
Newbie
Last Login: 5/27/2008 3:05:19 PM
Posts: 2, Visits: 5
I am no longer to close or open Crazytalk5.0 in Vista.  It also won't let me uninstall.  I don't want to try uninstall from command prompt and DOS.  Has anyone else had this problem?
Post #4574
Posted 5/5/2008 9:58:44 PM
Last Login: Yesterday @ 11:51:21 PM
Posts: 3,801, Visits: 6,294
Sorry to hear about your problems with Crazytalk 5.
I'm a little puzzled by how you aren't able to close it if you can't open it in the first place and vice versa. Maybe the program had just stopped responding and needed closing from the task manager.
If you find the program unresponsive you can open the Task Manager by Right Clicking on the Task Bar and choosing Task Manager. Then select Crazytalk 5 and choose to End Task.
If you are able to close the program then you should find it will then open again afterwards as long as the Crazytalk executable has been cleared from the task list. A restart of your computer will also remove it from the task list.
If this does not help your problem then contact support for further help. You can use the support form to request assistance. Please give as much detail as you can about the problem and describe what you were doing when the problem first occured. The more information given normally helps resolve it quicker.
Peter Edwards
Post #4579
Posted 5/18/2008 5:05:21 PM
Newbie
Posts: 2, Visits: 5
When I said close I meant it won't let me uninstall.  It won't start.  I get the message setup.exe has stopped working.  I get the same message when I try to uninstall.
Post #4724
Posted 5/18/2008 7:43:44 PM
Have you been in contact with support? They will be the best bet for a resolution to this problem. Use the link I gave previously for the support form.
Hope you get this sorted out soon.
Peter Edwards
Post #4726
Posted 8/24/2008 2:18:21 PM
Last Login: 11/27/2009 10:37:32 AM
Posts: 32, Visits: 81
Ernie,
Did your problem ever get resolved ?
I am having the same problem can't install till I uninstall and can't uninstall.
Quite a circle
Post #8659
Posted 9/30/2008 4:07:39 PM
Newbie
Last Login: 9/30/2008 4:05:46 PM
Posts: 1, Visits: 1
Im getting the same thing setup.exe, it wont let me uninstall or install programms an its pissing me off i only put it together 3 days ago and its already playing up
Post #10324
Posted 2/19/2009 11:25:52 AM
Newbie
Last Login: 9/30/2009 2:56:31 AM
Posts: 1, Visits: 6
I've been using iClone 2 and iClone 3 on both my vista and xp machines without problem. But my CrazyTalk 5.0 doesn't work on the Vista Machine. I've already submitted my problem via the form but this still has not been resolved. Anyone with a solution? I'm praying the money I've spent on Crazytalk does not go to waste.
Post #15585
Posted 2/19/2009 3:47:55 PM
getmaven (2/19/2009)
Have you updated your copy of Crazytalk 5 to version 5.1? This may help resolve your problem.
If you have already contacted support then you should hear from them soon. As long as your PC meets the minimum requirements then you should be able to run Crazytalk 5 in Vista without problems as it is a supported OS.
Peter Edwards
Post #15593
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 6:30am
Execution: 0.328. 12 queries. Compression Enabled.
