Newbie
Last Login: 4/22/2008 3:24:22 PM
Visits: 2
| Is there a way to adjust the lip expressiveness for all the "words" in a file. I have a 2 minute clip that my client wants more lip expression. Instead of having to manually go in and adjust each word, is there a way I can increase the expressiveness for the entire clip?
Power User
Group: Senior Forum members
Last Login: 10/2/2008 8:28:05 AM
Visits: 999
Newbie
Last Login: 10/3/2008 9:31:00 PM
Visits: 6
| I am trying to adjust the intensity of the lips separate from adjusting the intensity of the Emotives. Is this possible? When I put the cursor in the lip line and "select all" all the lip markers are selected but moving the intensity bar also changes the intensity of the Emotives (facial expressions). There is a green box over the girls lips in your example image in the forum. Should I see this box when I have the lip line properly selected? If lips only intensity bar adjustment is possible, how do you "Drag and Select" the lip line as you state in the forum tutorial because I have the "hand" cursor and can't select anything unless I click in the lips line and select "select all". Thank you for your help.
