Technical Problems with Installing iClone Content
Technical Problems with Installing iClone ContentExpand / Collapse
Posted 4/13/2008 12:28:37 PM
Last Login: 10/12/2008 6:16:42 AM
Posts: 22, Visits: 94
When I double click on current freebie, cell phone, I get the following error message:
Set up program did not find iClone on your computer, the installation of this content pack will be terminated. Please purchase and install iClone before you install the content pack.
I do have iClone installed and it's open, when I try to install the content pack.
What should I do?
Post #4235
Posted 4/13/2008 5:41:16 PM
Posts: 3,319, Visits: 5,635
Try installing one of the other freebies to see if the same thing happens with them. If it does then it is likely that iClone is not correctly installed and registered with your system OS.
You may need to uninstall and reinstall the software again to ensure it is installed correctly. If you do attempt this make sure you backup any custom content to be safe.
It may be worth a shutdown and restart of the computer if you haven't already tried. This may solve the problem. It is certainly worth a try.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #4247
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 11:33am
Execution: 0.156. 10 queries. Compression Enabled.
