Group: Senior Forum members Last Login: 11/11/2009 1:49:20 PM Posts: 347, Visits: 1,328 |
| Question: Is there any way to edit texture in liveplants. I want to change for example savannah green
in a safari savannah
I mean a savannah in a dry season... I used 3dxchange 2 in order to convert the liveplants scene to a props...but liveplants are not kept in the prop.
Indeed even, when I converted the liveplants scene into another one via 3dxchange, the new one does not support liveplants...
Someone would have an idea on this topic ?
Thanks!
David-Josué
http://www.iclone-fr.blogspot.com/http://www.iclonetemplate.com
| | Hi David, I don't know if you are aware but there is a dry season savannah scene in the World Wilderness Pack 1. This will probably give the look you are after. Sadly the liveplant textures themselves are not editable and as you rightly say the liveplants themselves are lost when opening in 3DXchange. I think the dry savannah from WWP1 is your best answer in this case. Pete
Group: Senior Forum members Last Login: Today @ 4:25:50 AM Posts: 487, Visits: 2,040 |
