Non human Character proportion problem ?
12>>
Non human Character proportion problem ?Expand / Collapse
Posted 2/7/2010 12:59:16 PM
Newbie
Last Login: 2/25/2010 10:43:00 AM
Posts: 11, Visits: 147
Hi I trying to convert some animals (rigging is ok) for iclone but
when importing to iclone it's open very huge and proportion is can't change
I trying again in 3dsmax resizing the animal than import to iclone nothing change, same size
Any ideas ? thanks
http://maviadam3d.blogspot.com/
Post #40051
Posted 2/7/2010 11:32:01 PM
Veteran
Last Login: Yesterday @ 7:18:58 PM
Posts: 181, Visits: 854
Hi, did you reset XForm? Maybe it will help!
sw00000p
Post #40087
Posted 2/8/2010 1:36:13 PM
Last Login: Today @ 12:38:07 AM
Posts: 591, Visits: 1,622
Hi, i think i can help you, first i have two questions,
How did you rescale the bipped animals.  And what version of fbx did you use to transport the bipped animals?
Wil
Post #40145
Posted 2/8/2010 6:01:49 PM
Last Login: Yesterday @ 9:10:57 PM
Posts: 427, Visits: 1,218
Good evening MaviaDamm,...
If you rescaled the skeletton by selecting the root Bone and then used the scale tool, the skeletton will be restored with its original size upon import into iClone.
If you use the CAT Rig Resizer tool to perform the rescaling, the skeletton will retain its changes upon import into iClone.
Hope this helps.
Cheers!
 Join the community of iClone users at www.coolclones.com forum with a wide range of offerings; Hundreds of iCloneFreebies, Tips and Tricks, Tutorials and cordial interaction. The Ultimate mecca for iClone enthusiasts
Post #40166
Posted 2/10/2010 9:30:21 AM
Group: Senior Forum members
Last Login: Yesterday @ 4:53:06 PM
Posts: 637, Visits: 1,277
Easier Mavie!
Just select EVERYTHING and scale it down. Not really a need for CAT... or Mouse...
Eh..... Well mouse yes! because you use the mouse to select everything and scale it down.
Be sure NOTHING is hiden, by the way!
Mike
Mike Aparicio Reallusion Certified Content DeveloperReally Certified
Apparition's Good Friends Gallery - Lucky of me!
Post #40279
Posted 2/10/2010 11:50:49 AM
Hi, I think this will work for most cases but when there are motions embedded were the rootbone is involved the vertical motions will not act right. I can help if you give me  the answer i asked for.
Wil
Post #40295
Posted 2/11/2010 1:53:41 AM
Newbie
I select everything than scaled to small size.
I used fbx version 200611
I try to reset x form but nothing to change
thanks for interests I still trying to my huge animal for normalize
Post #40364
Posted 2/11/2010 1:07:02 PM
First you have to rescale the animal :
Okay in this case you can not do it with fbx so you have to Choose a bipped bone of the animal, Go to motion menu and choose  figure mode. Choose structure and change the height value(the total animal will become smaller) till you have the right size. In 90 % the motion will still working , if not, ask again help and i will explain to change the motion of the animal.
Post #40436
Posted 2/11/2010 1:10:31 PM
by the way, if you have change the height, you still have to transport with fbx and load it in Iclone to see what value you need with height. height works linear
Post #40438
Posted 2/13/2010 1:19:03 AM
Newbie
W.VEEKE (2/11/2010)
Okay in this case you can not do it with fbx so you have to Choose a bipped bone of the animal, Go to motion menu and choose figure mode. Choose structure and change the height value(the total animal will become smaller)till you have the right size. In 90 % the motionwill still working , if not, ask again help and i will explain to change the motion of theanimal.
Yes yes it works finally I change size to normal.Now the proportions child's play
very thanks W.VEEKE and friends
Post #40605
12>>
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 5:27am
Execution: 0.328. 11 queries. Compression Enabled.
