Newbie
Last Login: 10/3/2008 9:31:00 PM
Visits: 6
| On the demo script there are words and phrases that move back and forth across the lower portion of the screen, pop-up in the middle of the screen and zoom in and out. I can't find a tutorial that tells me how to have these custom text effects do all the movement they do in the demo script. I assume you have to import the custom text as an image but I haven't found a tutorial on how to make these imported images move quickly from side to side and appear then zoom in and out, then disappear.
Group: Moderators
Last Login: Today @ 8:56:49 PM
Visits: 2,791
| Hi, To get those text effects just do the following; Go to Script - Timeline Right Click on the SFX line and choose Property. Select Text SFX and then 2_Caption from the dropdown. Select your desired effect and then click Modify. Here you can change the text, font etc. Click Ok when done. You can also drag the new effect on the SFX line to make it longer if you wish. I hope this helps.  Pete
Newbie
Visits: 6
| Thanks Pete. Works Great!
Group: Moderators
Visits: 2,791
