Is there anyone out there that can tell me if I can change the color on a 3d block in props?
I am using it to hide the body of an avatar so just the head shows.
Thanks
if not you can make a head with no body. (using Iclone 2)
Use the free cheerleader from the forum. Other wise you will get ghosting.
Start by creating a solid black square texture in your graphics program of choice.
256 x 256 pixles is fine, and save it.
select skin, modify and load the black texture to the opacity. ( the arms and legs should disappear)
then you select the Upper (Lower or shoes) and in the modify tab, load this black square to the opacity. ( making the clothing disapear.)
remove the hair, and save the new character to your character library.
you can now select a new head for your character.
