also I have use another site to upload some of video and then I embedded file to my site; however when I use that site. It upload via avi file; I only get a green picture and voice only. maybe you can tell what I'm doing wrong. I don't understand the compression box that pops up.
Thank you.
You may want to take a look at the topic below as this covers the same question.
http://forum.reallusion.com/Topic3298-21-1.aspx
As Crazytalk will output an HTML page with the flash or wmv video you just need to incorporate this on your webpage. If you need help on creating a webpage or site I would recommend a search on Google as there are many 100's out there. Once you have mastered this you should have no trouble in adding the Crazytalk output to your page.
The problem you mention with the AVI video sounds like a codec issue. You can use WMV to avoid this and to check your video works ok.
Peter EdwardsForum Moderator
iClone Daily Blog
